Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V6
Old 06-15-2014, 05:27 PM   #1
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
IPF S/C real world HP?
SO I have an opportunity to pick up a new IPF S/C and I really want to know the real world HP & Torq. numbers.
This site advertised 435 HP, 360 lbs./ft TQ.
http://www.ipf-tuning.com/camaro-supercharger/
Anyone here have some dyno sheet from their V6 LFX install?
I think I'm stuck doing this S/C as I can remove it for smog in the future if needed.
I do like to track my car so I would think the flat linear curve of this S/C would work better for tracking...
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 06-15-2014, 07:07 PM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Those are real world numbers. Just to the crank. Though the numbers to the wheels vary usually. I can think of a few around 350-370whp I think, but Sycraft IIRC has like 410whp, and that's in the LFX dyno thread.
The centrifugal super does have a linear curve but it's hardly flat, though it does make quite a bit of power in the high ranges...
Edit: Here's that dyno graph. http://www.camaro5.com/forums/showpo...&postcount=170
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
Old 06-15-2014, 07:26 PM   #3
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
I say around 700 RWHP and 1200 RWTQ is expected...
Dyno numbers can vary, the track will tell the true story of how the engine is reacting.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 06-15-2014, 08:44 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
I'm guessing your joking right? lol
Mods:
Old 06-16-2014, 07:20 AM   #5
MagnumForceGB
Just a hair...
Too many variables for your dyno # but it should be over 300. If the graph isn't smooth than your car is pulling timing, costing you power.
Old 06-16-2014, 11:45 AM   #6
MagnumForceGB
You could also use Dashcommand and an OBD2 bluetooth to get some measurements that are questionable. This was mine from this morning:
Old 06-16-2014, 06:41 PM   #7
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Dam, nice numbers! Show off! lol
Might be interesting to do some before and after numbers with that to see what I gain......
Mods:
Old 06-17-2014, 01:26 PM   #8
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
IPF is really close to those numbers (crank) But you could have more. california shorty headers, ported intake just a few.
Sikoriko is offline   Reply With Quote
Old 06-18-2014, 08:13 AM   #9
hopepassgots
Drives: camaro
i think so,Dyno numbers can vary, the track will tell the true story of how the engine is reacting.thanks
hopepassgots is offline   Reply With Quote
