02-14-2010, 05:18 PM | #1 |
First time ever at the dragstrip!
I went to a a local drag stip today and raced for the first time! What a blast! I went many years ago in my really slow 1995 ext. cab truck just to see what it was like.
Well here is my best time. looks like my mph is high but had a hard time launching. This is also my first manual car ever to own. For any of you experts out there, whats your take on these times? 60ft etc. R/T: .699 60: 2.280 330: 5.939 1/8: 8.808 MPH: 86.27 1000: 11.239 1/4: 13.264 MPH: 113.55 |
02-14-2010, 06:04 PM | #2 | |
Drives: 2SS/RS CGM LS3 Join Date: Aug 2009
What are your mods? |
02-14-2010, 06:09 PM | #3 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
Man, you get that 60ft time under 2 sec. and you will have yourself nicely in the 12's. Are you stock?
02-14-2010, 06:18 PM | #4 |
Drives: ex-500hp v6 mustang Join Date: Oct 2008
hes trapping over 113, so no hes not stock
02-14-2010, 10:12 PM | #5 |
Drives: 57Chevy TrailblazerSS 73Camaro Join Date: Aug 2009
113...nice trap speed. Obviously need to get that traction issue addressed. What have you done to it to get a 113 trap speed?
02-14-2010, 10:16 PM | #6 |
Would rather be riding
Drives: No car no more Join Date: Jul 2009
I wouldnt sweat those 60 foot times too much if you are running stock tires/gear/rear suspension.
A set of sticky tires alone will get you in the 12's |
02-14-2010, 10:53 PM | #7 |
Drives: 2010 1SS Join Date: Dec 2009
Your 60 foot times are slow... you need more traction... another indicator is the 113mph trap speed and the 13.20 ET. 113mph is showing you have enough power to run deep in the 12's.
Also, your reaction time is sloooooooooooow. Leave on the last yellow if you're running a sportsman tree... Here's a tip... Lower your sun visor so you have to nod down to see the staging bulbs... then after you stage, move your head up until you can just see the last yellow (will take a few times practicing) then when you see the last yella', drop the hammer! Sam |
02-14-2010, 11:21 PM | #8 |
Track > 1/4 Mile
Not bad for your first time!
I have a 2LT and my 60ft was horrible. Basically I ran a 14.8 at ~93-94, it was my first time, anyways what's a tip for getting a better 60ft? Traction isn't really an issue in the V6's imo. When I raced I didn't have it in sport (i have an automatic) and I had traction control on, not sure how much of a difference that makes..
02-14-2010, 11:32 PM | #9 |
Drives: 2010 Camaro 2ss Join Date: Apr 2009
I ran my best at 13.17 by reving to about 2500 rpms and slowly letting off the clutch while pressing on the gas on the last yellow light. You know you got a good launch if you get thrown back in your seat when you go and not spinning tires, sliding around. This was with a M6 SS.
On another note, I hear letting your stock tire pressure go down to about 25 psi helps with launches. I've yet to try it though
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal |
02-15-2010, 04:11 AM | #10 |
WOW! thanks guys.. looks like I may have a quick car if i can get that 60 foot down! All I have done is to the car is a muffler delete. Good tip launching as soon as i see last yellow. I ran about 28 psi in the tires, wasn't sure how low i could go safely. Whats the lowest R/T iI should aim for without a redlight? Some guys I ran against had like a .05. There was 1 guy there with a 10 sec procharged '10SS. He said I really needed to get some drag radials to hook up.
02-15-2010, 05:08 AM | #11 | |
Also the outside temp was about 65F so I'm assuming I may run even quicker with some cooler air... If I can get traction that is. |
02-15-2010, 06:27 AM | #12 |
Drives: 2012 Camaro ZL1 SIM CTF Car M6 Join Date: Jan 2010
Nice numbers!
2012 ZL1,CTF Car, SIM MN6, Polished Wheels,The Rare Flat Black Insert. Proud member of the unofficial Camaro5 "Rodgers Chevrolet Fan Club" |
02-15-2010, 08:53 AM | #13 |
Yes,sticky tires or you are just playing around and will be inconsistent in both your 60foot times and ETs.
It's a catch 22 though, get traction issues resolved and you could break an axle shaft on these cars. |
02-15-2010, 09:20 AM | #14 |
Drives: 2012 Mustang GT Join Date: May 2009
Nice run. Your trap speed seems very high.
Do you have the full (scanned) time slip? ________ Toyota M Engine Specifications Last edited by jrc1122; 03-11-2011 at 10:48 PM. |
Tags |
drag, race, track |
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
The time has come - First test drive! | mjrchabot | 5th Gen Camaro SS LS LT General Discussions | 0 | 08-05-2009 08:33 PM |
First time Camaro owner, long time fan... needs advice | Kalden | Cosmetics and Lighting Modification Discussions | 3 | 07-12-2009 08:36 AM |
Long time tunring over | TJ91 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 10 | 06-19-2009 08:30 PM |
Time Is Right for a Sleek, Fast, New Camaro -WalletPop | camaro5 | 5th Gen Camaro SS LS LT General Discussions | 22 | 02-03-2009 05:41 PM |
My last day here for some time. | 13F20 | Off-topic Discussions | 52 | 09-24-2008 08:34 PM |
