Roto-Fab
Old 12-27-2012, 07:13 AM   #1
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Draining fuel tank
Need to get the fuel out of the tank for a new build, any good way without dropping it?
Can I siphon it out one of the lines under the car through the pump?
Another 1 of 371 '12 T3 LS3 M6's built.
Iam Broke is offline   Reply With Quote
Old 12-27-2012, 09:32 AM   #2
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Flip it upside down and shake. Lol. I dunno. I would be interested in hearing how its done. How full is it? Dropping it with a quarter tank shouldn't be too bad.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 12-27-2012, 09:34 AM   #3
ginsberg2@hotmail.com
Drives: ls3 camaro
i'd like to know
ginsberg2@hotmail.com is offline   Reply With Quote
Old 12-27-2012, 09:38 AM   #4
Iam Broke
PHAT B33
Iam Broke's Avatar
It's full for storage, that's why I need to drain it. Too heavy for this old man to drop it.
Old 12-27-2012, 09:43 AM   #5
Bradrulz
Drives: 2011 Camaro 1LT IOM
Could probably use a might vac pump to get it out.
MRT2.0 with Helmholtz Pipes, Cold Air Inductions CAI, 4-Pack Gauges, Flat Black Stripes, Added Spare Tire Kit, Elite Catch Can, Chrome 20" Wheels, HUD, ABL Doors, GM Dovetail, Matte Black Gills, Rear Fascia Blackout
Bradrulz is offline   Reply With Quote
Old 12-27-2012, 10:32 AM   #6
GEN-IV
Right Cam
GEN-IV's Avatar
Drives: 2010 LS3 / 79 Z28
Scanner software can run the pump with the engine off.
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
GEN-IV is offline   Reply With Quote
Old 12-27-2012, 10:41 AM   #7
Spektrum
Spektrum's Avatar
Drives: 2013 2SS 1LE
I would say the best way is to remove the fuel pump and then suck it out, but it looks like the fuel tank must be removed. Can you access the filler tube where it meets the tank? I'd disconnect there and start the siphon process.
Spektrum is offline   Reply With Quote
Old 12-27-2012, 10:42 AM   #8
tinmanwpk
Drives: 2010 CTS SportWagon 3.6 DI
Can you just drive it?
tinmanwpk is offline   Reply With Quote
Old 12-27-2012, 10:44 AM   #9
Iam Broke
PHAT B33
Iam Broke's Avatar
Might be an option, I'll have to crawl under and check it out.
Old 12-27-2012, 10:45 AM   #10
Iam Broke
PHAT B33
Iam Broke's Avatar
Too much crud on the roads. It's a garage queen. lol.
Old 12-27-2012, 10:46 AM   #11
Iam Broke
PHAT B33
Iam Broke's Avatar
I forgot about that, prob the best option. I have HPT Pro so it should be in there. Thanks!
Old 12-27-2012, 11:36 AM   #12
Spektrum
Spektrum's Avatar
I wouldn't drain it by using the fuel pump, just this risk of sucking up any sediment at the bottom of the tank could damage the pump itself. You never know what's in that tank, even on a vehicle that new.
Old 12-27-2012, 12:02 PM   #13
Iam Broke
PHAT B33
Iam Broke's Avatar
Holds 19 gal, I'll take out 17 or so, it'll be close enough to empty for my purpose.. I can stop when the Low Fuel light pops on. Pump pickup has a sock on it and with 3k miles total on it running an ethanol blend, it should be pretty clean anyway. Thanks.
Old 12-27-2012, 04:25 PM   #14
ChrisBlair
Buick 455 Fan
After removing more gas tanks than I want to recall, even when I was 26, and I could pick up my 455 engine block, a gas tank with a couple gallons in it was very hard to handle
