Old 12-16-2016, 06:12 AM   #1
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
Send a message via AIM to Blade
UPDATE.....Urgent: Should I add oil?
I think there is a thread out there talking about this so apologize to creating another one but I have to get ready to drive 550 miles.
Simple question, I have 720 miles on the car and about to total up another 1100 miles in the next 10 days. I checked my oil after the car sat there for a day and this is the status, should I add a quart?
There is oil right at the tip of the crosshatch.
Please reply and thank you!!!
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner
2010 LT/RS Build Thread - Traded in for 2012 2SS
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
Old 12-16-2016, 06:24 AM   #2
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
I would.
Old 12-16-2016, 06:36 AM   #3
V8Addict
V8Addict's Avatar
Drives: 2016 2SS
please do...it may even take over a quart to reach the top of the marks.
2016 Hyper Blue 2SS, A8, NPP, MRC
V8Addict is offline   Reply With Quote
Old 12-16-2016, 06:56 AM   #4
Max RS
Max RS's Avatar
Drives: 2016 SS AT
I would add oil a half quart at a time and then give it plenty of time to drain down. I usually wait at least an hour, recheck and add more if needed. The slow draining back is a pain when trying to check your oil but a big positive in that it keeps the oil up top for lubrication when you shut-down and re-start a lot.
1969 Z-28, 302 4-Speed Sold
1989 350 AT Sold
2013 RS Convertible LFX AT Traded
2016 2SS AT
Max RS is offline   Reply With Quote
Old 12-16-2016, 07:52 AM   #5
m666etal
Drives: Civic
Without wanting to sound stupid, had a question: Doesn't the engine sensors alert you via the dash when you need an oil change(scheduled maintenance)? Also, the oil life percentage that comes up on the dash?
m666etal is offline   Reply With Quote
Old 12-16-2016, 08:34 AM   #6
Jeb114
Jeb114's Avatar
Drives: 2021 300
Yes.
Jeb114 is offline   Reply With Quote
Old 12-16-2016, 08:39 AM   #7
DenverTaco07
DenverTaco07's Avatar
probably not sensors, more of a calculation based on time and driving habits, i.e. stomping the gas all the time vs. driving Ms. Daisy, the car knows how your driving affects the life of the oil.
Old 12-16-2016, 08:41 AM   #8
camaromike77
camaromike77's Avatar
Drives: S O L D
^^ I agree ^^
Club F1FTY
Old 12-16-2016, 08:41 AM   #9
Blade
Blade's Avatar
Originally Posted by vtirocz View Post
I would.
Thank you! I know I can check the OLM but 500 miles ago, when I checked oil under similar conditions, the whole hash was filled with oil so I felt alarmed last night. I know the first 1500 oil can be consumed at a higher rate. But this was weird.
The concern with OLM within the first 1500 miles is that GM isn't clear on if they are actually actively monitoring the oil consumption or is it based on a canned formula based on miles driven.
I will pick up a quart of Mobil-1 and monitor carefully.
Formerly owner of:
2007 Acura TSX
1992 Mercury Sable
Old 12-16-2016, 08:52 AM   #10
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
As others have said, the old drains very slowly from the top of this engine. So make sure there is a decent amount of time between shutting off the engine & checking the oil level. You may be surprised & accidentally overfill it.
But if indeed you are low, dropping that amount of oil with such few miles would have me monitoring it very frequently. My car burned off a quart during initial 1K miles, then seems to have settled in & the oil level has held steady since. I'm at 3K now.
BrianL is offline   Reply With Quote
Old 12-16-2016, 09:03 AM   #11
ChevyRules
Drives: 2021 Tesla Model 3 LR
The OLM is about how long the oil is still good for before you need to change it based on fancy math. Oil level is not a part of it. The OLM may say 90% but be 2 quarts low on oil. I believe there is a separate sensor that will set off a low oil level alert, but not sure at how low it will go off.
Ultimately it is still your responsibility to check the oil level yourself. The Oil life monitor is not an oil level monitor.
ChevyRules is offline   Reply With Quote
Old 12-16-2016, 09:10 AM   #12
tsanchez18
Software Architect
tsanchez18's Avatar
Drives: 2017 Camaro 2.0L Turbo
follow up question. What kind of oil should one get?
tsanchez18 is offline   Reply With Quote
Old 12-16-2016, 09:20 AM   #13
4xlr8n
Red Hot
4xlr8n's Avatar
Drives: 2017 Camaro RS
exactly
4xlr8n is offline   Reply With Quote
Old 12-16-2016, 09:32 AM   #14
Blade
Blade's Avatar
On point bub ��
Formerly owner of:
2007 Acura TSX
1992 Mercury Sable
