Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Transmission / Driveline
Old 01-18-2022, 03:22 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
2016-2019 CAMARO MOMENTUM GT PRO DRY S STAGE-2 INTAKE SYSTEM
Increasing the engine's overall performance is number one on every car guys list. The stock intake system is one of the most restricting parts on your vehicle by limiting the amount of air the engine receives. Replacing the stock cold air intake will add horsepower and torque you can hear and feel. The more air your engine gets, the more power it will produce. aFe's Momentum Series Cold Air Intakes are designed using the most up-to-date engineering tools and techniques to provide you with the perfect blend of power and protection.
Unique One-Piece High-Quality Housing W/ Sight Window:
A custom CAD designed roto-molded housing made from heat soak resistant material eliminates the use of multiple components and ensures the coolest air intake charge available. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene. A urethane plug is also included if you wish to completely seal the auxiliary air scoop.
High-Quality Tube:
This system uses a high-quality plastic CAD designed, dyno-tuned, roto-molded intake tube to achieve maximum power gains while maintaining a perfect fit. Also included is a high-quality billet aluminum crankcase fitting provided for easy installation. This tube has a built-in resonance chamber to catch unwanted air intake noises.
High-Quality Scoop:
A high-quality CAD air scoop guides cool ambient air to the performance air filter.
Large 3-Layer Performance Air Filter:
This Momentum GT intake system was designed around the largest filter possible to allow maximum performance and filtration. This cylindrical filter has a large oval (6-3/4" x 4-3/4") flange and is 9" tall inverted top Pro DRY S filter media. The Pro DRY S performance air filter features 3-layers of progressive finer porosity synthetic media providing maximum convenience with 100% polyurethane frame for long life and multiple cleaning cycles.
Premium Hardware:
Premium stainless steel T-bolt clamps and a reinforced silicone elbow coupling are used for strength and durability while also providing the most secure installation available. Momentum intakes are designed with fewer parts for a quick and simple installation.
Note: This intake system is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles.
Fitment: 2016, 2017, 2018, 2019 Chevrolet Camaro
southerncarparts is offline   Reply With Quote
Old 07-15-2022, 12:27 PM   #2
southerncarparts
Old 01-06-2023, 01:34 AM   #3
southerncarparts
Thank You for shopping at https://www.southerncarparts.com/201...ke-system.html
