Old 09-18-2015, 08:58 PM   #1
Tenring
Tenring's Avatar
Drives: 2014 2SS/RS - SIM
Started header install & found this
2014 2SS 15K
Pulled the plug wires and manifold shield and was just getting a few things ready for the header install tomorrow. Looks like my steering box is leaking?
I am not sure if it is a big deal or not, but now I am wondering if I should go through with the install or take it in to the dealer first? What would you do?
Tenring is offline   Reply With Quote
Old 09-18-2015, 09:13 PM   #2
Rys14SS
Drives: 2014 Camaro 1SS/RS
Might be normal? I have the same thing/grease going on near the steering area.
Rys14SS is offline   Reply With Quote
Old 09-18-2015, 10:14 PM   #3
Tenring
Tenring's Avatar
Thanks Rys......was thinking the same but just not sure.
Old 09-19-2015, 08:40 AM   #4
Tenring
Tenring's Avatar
Going ahead with the install today, deal with the leak, if it is one later.
Old 09-19-2015, 09:15 AM   #5
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Same with mine, I only have 7k on mine and there's a slight leak there.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 09-19-2015, 11:17 AM   #6
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
you're under warranty. take it to the dealer like it is and get it fixed.
Old 09-19-2015, 11:33 AM   #7
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
Interesting difference.
I went out to looked at mine then realized yours is the newer electronic assist vs. the hydraulic on mine. Just for kicks I'll post a pic. Kind of interesting in the differences between the two. The steering box and the length of the shaft from the box to the U-joint is different. The shaft length from the box to the U-joint looks shorter on the 2014. Mine measures about 4 3/4". No doubt that would make a difference in the manufacturing of the header clearance in that area. As far as your seepage of fluid, looks a little excessive.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 09-19-2015, 02:47 PM   #8
Tenring
Tenring's Avatar
Right on guys thanks....manifolds are out and headers are going in, (on break) hope to fire her back up in a few hours. Getting tired and progress is slowing ha ha.
Power steering conditioner, might give it a shot and clean it up see how it goes, just not today.
Old 09-19-2015, 03:12 PM   #9
GMTool
MY SS is SOLD
GMTool's Avatar
Might not want to clean it in case you decide to show it to the dealer. I always hate it when some thing is leaking and I clean it up then I want to take it to dealer, but there's nothing to show them because I cleaned it up.
Old 09-19-2015, 04:10 PM   #10
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Where the hell would you put power steering fluid /conditioner into on a 2014 with electric power steering ?
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 09-19-2015, 04:51 PM   #11
GMTool
MY SS is SOLD
GMTool's Avatar
LOL, good point. I read that above and it didn't click. If some thing is leaking or seeping and it's not suppose to be, and it's under warranty. Easy, take it to the dealer.
Old 09-20-2015, 12:17 AM   #12
Tenring
Tenring's Avatar
Ok install complete, running good and sounds awesome. No idea how some of you install headers by yourself wow, thank goodness I had my son to help me.
Note to self..........when you disconnect the battery DO NOT close the trunk!!
Old 09-20-2015, 08:09 AM   #13
BlakeD
Drives: 2015 Camaro SS 1LE
Which headers did you go with? I thought you had to tune with headers? If not, would love to get some on mine!
2013 2SS RS
CAI Intake
Air Scope
BMR Strut Bar
Tune
BlakeD is offline   Reply With Quote
Old 09-20-2015, 08:55 AM   #14
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
U do need a tune. But u can wait as long as u want
Pity a man in familiar places, who yet feels like a stranger.
Homeless Man is offline   Reply With Quote
