Old 07-06-2018, 12:31 PM   #477
Redlinez
Shifts under load
Redlinez's Avatar
It's the lower part of my windshield. I've never had any other of my stupid number of cars do it though.
22 Suzuki GSX-S 1000GT blue
Old 07-06-2018, 01:14 PM   #478
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
in some places like Florida it makes it just about impossible to see through the windshield. At night with cars coming you loose alot of the the little viability you have. It is a safety issue that should be a mandatory recall. The only way to fix it would be to remove the heat ac box and put a seal on the vent door to keep it from leaking.
Old 07-06-2018, 04:09 PM   #479
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
You are correct sir! I've been posting this for three years.
This thread has full info.
Like the windshield must be removed, and it breaks.
They do not pull the HVAC unit.
GM has no fix other than one to remove a foam spacer they added to make the mode door leak to stop flutter noise on high fan speed.
They have the tech make a hook from a coat hanger to remove their added spacer.
Then it STILL leaks! Units after the spacer was stopped, leak too.
One of many reasons I am not able to buy this car.
3 years! No fix, just F it!
d
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 07-06-2018, 06:22 PM   #480
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
Originally Posted by DangerZL1 View Post
Are the 2018 models affected by this problem too?
the beginning of the week when it was in the 90's i had it on it didn't fog up. i guess i got one that doesn't fog up.
NYJets12 is offline   Reply With Quote
Old 07-08-2018, 07:31 AM   #481
18Hotwheels-SS
18Hotwheels-SS's Avatar
Drives: 2018 Hotwheels 2SS #117
I have owned a lot of cars and never had this issue daily, I haven't had the time to get through all the replies but when i read its normal I had to respond. The most likely cause is a blend door seal that does not seal properly or a poorly designed HVAC box. I am responding to a thread from 2016 and i just bought 2 2018's and have had the problem on both from day one. I will read on and see what i find out. " ITS CALLED PHYSICS PEOPLE!!" is a stupid reply. So your saying that my 2017 Hellcat, 2008 srt8, and every other car or truck i owned defied PHYSICS. REALLY!!!
2018 Yellow ZL1, Just bought.
2018 Hot Wheels 2SS #117, For Sale
2018 Hot Wheels 2LT Convertible. #506, Still Have
2018 Dodge Ram 3500 Cummins Long Horn, Still Have
2017 Challenger Hellcat
2008 Challenger SRT8
1970 Camaro RS/Z28, Still Have
1955 Willys CJ3B, Still Have
18Hotwheels-SS is offline   Reply With Quote
Old 07-08-2018, 07:52 AM   #482
18Hotwheels-SS
YES I HAVE 2, 2018 CAMARO'S THAT DO IT
Old 07-08-2018, 07:55 AM   #483
18Hotwheels-SS
Just an idea, GM could come up with a low temp heating grid that would fit in the vent and only come on when the defrost id off. not hot but a lets say a 80 deg grid that worms the air leaking out the seal.
Old 07-08-2018, 02:31 PM   #484
indyz
Drives: 2SS, CT-R, LC500
You expect too much from GM.
They got your money, now leave them alone lol
indyz is offline   Reply With Quote
Old 07-08-2018, 11:07 PM   #485
camaro5
camaro5's Avatar
File a Vehicle Safety Complaint
Many already have, the more the better to get action
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
STANDARD DISCLAIMER
Old 10-03-2018, 04:25 PM   #486
sport65
sport65's Avatar
Drives: 2018 Camaro 2SS, Hyper Blue, NPP,A8
A fix I am using is simply cutting felt paper to the size of the opening. Then put a 1 inch by 1 inch piece of hook, from hook and loop (Velcro), hook side stuck to felt paper at the forward edge of the felt paper. Remove sticky side from hook, slide the hole piece into position. Push up ( I used a screwdriver to stick hook piece to windshield) when it is under the black window edge so its not seen. It will pull off when you want, wont slide off from spirited driving (Maybe the ZL1 guys will need 2 pieces of velcro).
I used black because it was sitting around the garage, but it looks like a dark grey would match better. Its easy to trim and get it to look good, and cheap when you make mistakes. It looks somewhat factory to me. I took a picture but cant post it. Hope this helps
sport65 is offline   Reply With Quote
Old 10-03-2018, 05:06 PM   #487
sport65
sport65's Avatar
Figured it out. Ignore the bugs on the windshield.
Old 10-09-2018, 12:25 PM   #488
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
This is what is preventing me from getting a 6th.
JLSuperfly is offline   Reply With Quote
Old 10-16-2018, 10:15 AM   #489
Bradl1982
Drives: 17 Camaro 2SS
Another year down. Windshield fogging season is officially over here in the St. Louis area. haha
Bradl1982 is offline   Reply With Quote
Old 10-28-2018, 09:05 AM   #490
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
Seriously...? THIS issue is what's keeping you from getting a 6th Gen? Holy cow...so easy to mitigate. I applied a similar fix and I don't even think about it anymore. It's been raining and humid where I live for a couple weeks now and I had to look at my dash to remind myself it was still in place.
Go get your 6th Gen...this issue is the least of the things you should be worried about. The A8 torque converter shudder is more significant. I've had the 3X fluid flush, my TC replaced once, and I would do it again, in a heartbeat, to keep driving this car!
#permanentperma-grin4me.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
