09-23-2013, 10:28 AM | #1 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
HELP: Noise at rear wheel.
I have a clicking sound coming from the left rear wheel. Did anyone have this problem and what was it?
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
09-23-2013, 10:53 AM | #2 |
Let's go Rangers!
09-23-2013, 11:17 AM | #3 | |
09-27-2013, 11:45 PM | #4 |
Drives: a6 yellow 2ss/rs Join Date: Sep 2013
I have absolutely no clue what it is, but I
09-27-2013, 11:45 PM | #5 |
also have a clicking noise, but mine comes from the right rear wheel.
09-28-2013, 12:36 AM | #6 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
I have a clicking sound that comes from the rear (not sure which side). It happens sometimes when I hit a bump, pull in my driveway and even sometimes when I'm on smooth pavement and the car's weight shifts. I can't figure it out for the life of me...
09-28-2013, 01:09 AM | #7 |
www.Camaro5store.com
If the clicking comes when the load of the car shifts forwards and backwards (pull forward, then backward, then forward, then backward NOT using the brakes - in manuals) and if you get the clink, clink as you go back and forward, you can bet your bottom dollar it's the axle nuts and washers. See the TSB.
E.T., yours sounds more like a sway bar issue....possibly an end link issue. Check the rear sway bar first. Make sure all 4 bolts holding it to the frame are nice and tight. I had a couple bolts strip on me causing the bar to come loose...and it would clank loudly as I hit bumps or would go over uneven surfaces. But a very large majority of the problems stemmed from people having the above linked issue. Talk about a PAIN...IN...THE...ASS... It was driving me NUTS. |
09-28-2013, 01:23 AM | #8 | |
I read a thread where the bolts at the top of the shocks were hitting the bottom of the trunk and making noise, but supposedly this was fixed on the 2012, which I have.
