TireRack
Old 12-30-2015, 11:14 AM   #1
MoCamaro20
MoCamaro20's Avatar
Drives: 2010 Camaro SS RS L99
Any bagged camaros on here??
Thinking about bagging my camaro!
MoCamaro20 is offline   Reply With Quote
Old 12-30-2015, 02:31 PM   #2
scandata
scandata's Avatar
Drives: 2015 2SS/RS vert, Spring Green Edtn
Will that be paper or plastic?
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015)
http://img.photobucket.com/albums/v692/scandata/sigpic_zpsxmxmbipg.jpg
scandata is offline   Reply With Quote
Old 12-30-2015, 02:48 PM   #3
maguilar496
maguilar496's Avatar
Drives: 96 camaro
Lol.
maguilar496 is offline   Reply With Quote
Old 12-30-2015, 02:49 PM   #4
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
If plan A is to bag your Camaro ... go with plan B.
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 12-30-2015, 03:01 PM   #5
GrandAmGT
GrandAmGT's Avatar
Drives: 2010 1LT & 2016 Cadillac CTS V6
I'm all fuzzy on the bagging thing.
GrandAmGT is offline   Reply With Quote
Old 12-30-2015, 03:07 PM   #6
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 12-30-2015, 03:13 PM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Hmm, take an awesome handling car and ruin that with airbags. Probably should find an old 60s boat for that. Then you are improving on stock not degrading it.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 12-30-2015, 03:20 PM   #8
c5Legend
Camaro5
c5Legend's Avatar
Drives: 2010 Camaro 2LT
I see em on IG all the time and they look great when very low, might find better answers there.
My Build
'11 Chrysler 300 Limited / '10 Camaro 2LT
c5Legend is offline   Reply With Quote
Old 12-30-2015, 08:37 PM   #9
MoCamaro20
MoCamaro20's Avatar
Actually with bags you can litterally adjust anything. A lot of cars are bagged. It's good quality and you can adjust it for whatever you are planing on doing that day
Old 12-30-2015, 10:56 PM   #10
Bmatth1162
Bmatth1162's Avatar
Drives: 2011 1SS/RS LS3
I agree! You an adjust a bagged car as needed depending on if you're going to a Bernie Sanders convention, a Vape show, instagramicon, or a Justin Bieber concert.
CAI intake, apex scoop, Vmax ported TB, MGW short throw, BMR 1" springs and sways
Bmatth1162 is offline   Reply With Quote
Old 12-30-2015, 11:51 PM   #11
SS376
SS376's Avatar
Drives: 2013 1SS LS3
You sir, have a sharp wit
SS376 is offline   Reply With Quote
Old 12-30-2015, 11:57 PM   #12
SS376
SS376's Avatar
"Litterally" adjust anything? Anything? It sounds like bags are very versatile. Who knew.
Old 12-31-2015, 12:30 AM   #13
Dubscamaro
Living Life in MPH.
Dubscamaro's Avatar
Drives: 15 Summit White 2SS 1LE
Bags are for groceries
Dubscamaro is offline   Reply With Quote
Old 12-31-2015, 12:35 AM   #14
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Idk for me I rather go coilovers than bags. I have friends that have bags and it looks cool, but it just takes up trunk space. Unless you put the tank and compressors where the spare tire goes so it is hidden, but people like to show off there setup.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
bags camaro
