Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 05-28-2015, 01:37 AM   #1
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2022 SS 1LE
Dual oil coolers for serious track duty
Hi guys,
After I built my 416 which was generating tons of heat, the oil temps were sky high within 3 laps even on a mild day. To remedy this, I had dual oil coolers installed to the left and right of the radiator. We threw the 1LE oil cooler in the trash, and installed these air to oil coolers instead. Now the radiator no longer cools the oil, so the coolant also runs nice and cool on a hot track day after many hard laps.
They each have custom shrouds that funnel the air from the high pressure grille openings through the coolers. I sold the Camaro so I can't do a thorough photo shoot or write up, but I'll do my best. Partial parts list:
2x Setrab 20-row oil coolers, 50-920-7612
Setrab EGM-113 lo profile oil cooler thermostat
SETM22AN8 -8 22mm oil cooler adapter
-8 Perform-o-flex hose
2x custom shrouds
7's Only Racing at Buttonwillow Raceway did all of the work, top notch shop. If you are fortunate enough to be in CA, drop off your car with Tom and Bette and they will take care of you.
Attached are a couple of pics, sorry they aren't the best but they are what I still had in my phone.
And to all that had requested this along time ago, sorry I took so long guys. I am running a full season of SCCA racing in the Mustang now. Really miss the Camaro, but am enjoying racing in the 'Stang.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 05-29-2015, 08:17 AM   #2
jamestown
jamestown's Avatar
Drives: 2014 1le
Hey thanks for taking the time to post this! GL with your Mustang!
jamestown is offline   Reply With Quote
Old 05-29-2015, 09:41 AM   #3
Orange Crush 1LE
Drives: 2022 SS 1LE
You're welcome. By the way, I miss my Camaro. The Camaro's handling is a lot more predictable at the limit, and boy do I miss the power! The Mustang class rules dictate the stock 4.6L, it's totally out of steam in fourth gear. But the racing is competitive and the adrenaline rush is addictive
Old 05-29-2015, 12:58 PM   #4
forklord
forklord's Avatar
Drives: 2010 2SS
So what exactly didnyou do with the stock oil cooler ports?? And what oil pump did you run?
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 05-29-2015, 02:44 PM   #5
Orange Crush 1LE
Drives: 2022 SS 1LE
The lines that went to the 1LE cooler were rerouted to the new coolers, and no longer go through the radiator. Stock oil pump that came on 1LE. In combination with the Improved Racing oil pan baffle, it works flawlessly. I verified this by continually monitoring oil pressure and oil temp including through long high g sweepers. With slicks and downforce, no oil starvation at all. No need for a dry sump system.
Old 05-29-2015, 02:53 PM   #6
hcsi99
Cadillac Service Manager
hcsi99's Avatar
Drives: 2014 Camaro 1SS, 1LE, NPP, RECAROS
What was the highest oil temp you saw after the cooler install?
hcsi99 is offline   Reply With Quote
Old 05-29-2015, 04:27 PM   #7
Orange Crush 1LE
Drives: 2022 SS 1LE
Oil Temp:
Before oil coolers: 290 F in 3 laps, had to back off.
After oil coolers: 220 F max in 25 min. sessions; Ran hard for two days!
I also noticed coolant temps lower, I think I only hit 207 F the entire day.
This was on a mild day, I want to say in the 60s to 70s ambient, but I don't recall. On a hot day, these coolers should be able to take anything I throw at them.
They need to add this setup to the C7 Z06, LOL
Old 05-29-2015, 06:17 PM   #8
hcsi99
hcsi99's Avatar
Thanks! Hope your 1LE went to a good home.
Old 05-29-2015, 06:26 PM   #9
Orange Crush 1LE
Drives: 2022 SS 1LE
No problem.
Yes, the Camaro was purchased by a track rat in New Zealand! Kind of cool. He races and also does fun track days with his buddies, the Camaro will be his toy that he can drive to the track with AC and comfort.
Old 05-30-2015, 12:22 AM   #10
backeddy
Drives: 2011 Boxster Spyder (best car ever)
Damn OC that looks like right where my brake vents are?
backeddy is offline   Reply With Quote
Old 05-30-2015, 01:50 AM   #11
Orange Crush 1LE
Drives: 2022 SS 1LE
Yep, it's the ideal place on the front end as the high pressure will flow air though it per the GM engineers. If I had kept my Camaro, I was going to do brake ducts through the fog light holes. Not as good, but hopefully good enough.
Old 05-30-2015, 01:26 PM   #12
backeddy
so OC, how does that stang handle? how is the bottom of the corkscrew with a solid axle?
Old 05-30-2015, 01:36 PM   #13
Orange Crush 1LE
Drives: 2022 SS 1LE
Not too bad at the bottom of the corkscrew with the correct line. The Mustang turns in well, however it is loose off. So as you exit a corner, you cannot use nearly as much throttle as you can on the Camaro, Viper or a C6 Vette (the cars I have the most track time with). When the ass end steps out, it is harder to catch than any of the above cars. Steering is numb. So it is a harder car to drive near the limit, which is where you are the entire race. It is however, pretty good and is fast enough. I have turned a 2:00.3 at Thunderhill even with the car not aligned correctly (only -2 degrees camber, needs -3). I have also turned a 1:41 at Laguna Seca. Still learning Laguna Seca though, I hope to be in the 1:39s soon. This is a 2005 Mustang with stock 4.6L, so it's not exactly a rocket. Not in the same league as a stock 1LE, but still really fun to race with a bunch of other like cars.
Old 05-30-2015, 09:37 PM   #14
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
Hey, your having fun doing what you like to do so I'd say its a good day! Hope someone is getting some use out of the 1LE.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
