Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 11-04-2014, 03:39 PM   #1
MAXRS
MAXRS's Avatar
Drives: Camaro RS
Exclamation Issue after pumping gas!
So...I'm having an issue on my 2010 camaro v6 RS 3.6L. Car has 117xxx miles if that maters. So here is the problem, every time after pumping gas I have problems starting the car. Usually to avoid this problem i turn the key before the ignition let the fuel pump flow some gas and then start it any ideas what it might be? would codes be useful? I appreciate everyone's help in advance.
2010 CAMARO RS CGM 2LT
MAXRS is offline   Reply With Quote
Old 11-04-2014, 04:50 PM   #2
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Mimic the samething you do when you pump gas, but do not add gas or take gas cap off. Filling up my have nothing to do with it. Posibbly just sitting with with ignition off and a hot engine for 5 minutes or so may cause the same issue.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 11-04-2014, 04:51 PM   #3
TheSmokingSuns
TheSmokingSuns's Avatar
Drives: 2017 Camaro 2SS, 2011 Camaro 2LT
Post a vid
TheSmokingSuns is offline   Reply With Quote
Old 12-01-2014, 11:15 AM   #4
MAXRS
MAXRS's Avatar
Drives: Camaro RS
Bump...
Old 12-01-2014, 01:51 PM   #5
OUTATIME
OUTATIME's Avatar
Drives: 2010 IOM 2SS/RS
Not that I would recommend trying this regularly - but does this happen when your tank was near empty, and then filled it up? I'd try to see if it happens when the tank is just near empty a few times. It might be your fuel pump slowly dying.
Also, I've seen fuel pumps die prematurely when people consistently fill up only when their gas light comes on, or continuously pull a Kramer and try to run the tank to empty before filling. If you've been doing that, it's a bad practice.
OUTATIME is offline   Reply With Quote
Old 12-02-2014, 02:29 PM   #6
MAXRS
MAXRS's Avatar
Drives: Camaro RS
Ive actually always filled up once it's only one quarter of a tank left on it never let it go below that and always go full tank when ever I do pump gas
Old 12-02-2014, 03:16 PM   #7
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Could be the start of the in-tank fuel pump going out. You asked if codes would be helpful... is your check engine light on? Codes are always helpful if you have them.
TommyTheCat is offline   Reply With Quote
Old 12-06-2014, 04:18 PM   #8
MAXRS
MAXRS's Avatar
Drives: Camaro RS
Yes, Ill post codes in a bit thank you for everyones help problme is still going on still havent had time to lower the tank and check whats going on
Old 12-06-2014, 09:42 PM   #9
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
The replies above are all pretty good suggestions.
My only suggestion is to always allow the fuel pump to prime before starting the engine. Just turn the key to the 'Run' position (before 'Start' position) and wait about 5 seconds. You can then turn the key to start the engine. This is a good routine for any fuel injected car.
I cringe every time I hear/see someone immediately start cars after inserting the key.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 12-07-2014, 08:32 AM   #10
jravenfan
Drives: 2013 2SS Blue Ray Metallic
I does sound like the fule pump going bad, does it happen even if you haven't pumped gas?
try to simulate the same type of timing but without pumping gas.
jravenfan is offline   Reply With Quote
Old 12-07-2014, 05:01 PM   #11
TooCool5
TooCool5's Avatar
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP
Try some fuel treatment that removes water like Chemtool.
Could be water stirred up or the strainer clogged.
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
TooCool5 is offline   Reply With Quote
Old 12-07-2014, 07:31 PM   #12
Kendall421
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE
None of the above. Just had the same problem with my Traverse. The GM fuel systems are all similar in the emissions setup and that is your problem. There is a pressure relief valve at the tank, then a hose that runs to the engine. There is another pressure relief valve there...typically on top of the engine. Typically the valve at the engine fails. When this happens, the car won't start well after a fill up...pressure not properly balanced in the tank and computer won't let it start. I used to have to hold the pedal to the floor for a few seconds and release...then it would start. Replaced this valve on top of the engine and problem solved.
Google "Camaro won't start after filling gas tank" and see what yo find. That is how I found what was causing it on my Traverse. $46 part.
Edit...just did the search...best result: the purge solenoid is stuck open...when you fill the tank...the fumes from the tank go into the engine through the open purge solenoid and flood the engine.
Replace the purge solenoid...that is what I replaced on my Traverse.
Kendall421 is offline   Reply With Quote
Old 12-09-2014, 11:28 AM   #13
MAXRS
MAXRS's Avatar
Drives: Camaro RS
Can anyone help me locate the fuel solenoid please?
Old 12-09-2014, 12:35 PM   #14
MAXRS
MAXRS's Avatar
Drives: Camaro RS
Kendall421 Did some research before and also got that as well but going to change it today hopefully it is whats causing the problem thanks to everyone I will keep everyone posted to see if this was the problem again I am replacing the
Purge solenoid
