09-16-2023, 05:25 PM | #15 | |
I feel the run was terrible due to my noob skills and the power drop off was really noticeable because the heat pulling my timing. (10 degrees) A month prior at the same track but unprepared, it ran a 12.5 at 127mph after spinning in 1st and 2nd gear so I know there's more speed to be had if conditions and my skills were spot on. |
09-16-2023, 05:57 PM | #16 |
Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
127mph? Oh hell you got 10s in there if you can get it out of the hole. Cooler weather and tire and it's possible.There are guys with big cam ss in the low 11s high 10s with 124mph or around there, though most are autos but you certainly got the power for 10s. Makes me wish I threw down the coin for a zl1 to begin with. Everything about it is an ss on steriods. Easy to make big power and still run daily if you wanted to. You will get there!
09-16-2023, 05:59 PM | #17 | |
09-17-2023, 04:47 PM | #18 |
Drives: 2011 Camaro SS Join Date: Jul 2019
I ran an 11.7 @ 114 in 100 degree heat in July. You definitely are low 11s with that trap
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
09-17-2023, 06:00 PM | #19 |
09-17-2023, 06:47 PM | #20 |
You will get there..your trap is key..the rest is seat time.
