11-06-2023, 11:22 AM | #1261 |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
That covers a lot of ground. What aspect of NCAS would you want my thoughts?
Never mind… re-read your question and I get what you’re asking. My thinking is if I’m GM and I’m looking at a portfolio of vehicles that are using CCS charging solutions, the quality and reliability of them is variable by hardware manufacturer and by charging network provider. If I am looking at NACS they are like Coke. You know what’s in the bottle (even if the bottlers are regional). Additionally, by being able to adapt to the NACS standard, in one fell swoop you’ve added 24,000 charge points (and growing) to the accessible chargers for GM EVs.
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
11-06-2023, 11:51 AM | #1262 | |
Drives: 2021 Tesla Model 3 LR Join Date: May 2016
Hopefully from having to now compete with the superchargers, EA and co actually care about reliability and do something about it...... Last edited by ChevyRules; 11-06-2023 at 04:03 PM. |
11-07-2023, 12:46 PM | #1263 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Finally, someone introduced a hybrid "series" vehicle that actually makes sense in a class of vehicle where full EV is the wrong answer. This is the answer...my opinion, this is what all manufactures should be pushing today instead of EV in all classes of vehicles except for perhaps ones that are billed as short commuter vehicles.
RAM introduce the RamCharger today: https://www.caranddriver.com/news/a4...harger-towing/ It's basically a bigger Chevrolet Volt. It goes 145 miles on full battery. Enough that most people will never have a need to use gas most of the time...which should please those zero or near-zero emissions folk. After that, a gas engine kicks in to power the battery (not the wheels) and is even able to keep the battery charged while towing with the only anxiety being when you need to fill it up with more gas to keep going. The only downside I see (which is of course pretty significant) is that it will likely cost way more than the full ICE truck, but should be cheaper than the full EV truck the RAM REV.
2010 Camaro 1LT V6 (Sold. I will miss her!) Last edited by KMPrenger; 11-07-2023 at 01:10 PM. |
11-07-2023, 02:26 PM | #1264 |
Since it is a series hybrid with the engine just being a generator, diesel would be ideal since the generator would be running at a steady RPM, but I imagine that would just make it even more expensive due to the added costs diesels bring these days.
11-07-2023, 03:52 PM | #1265 | |
2010 Camaro 1LT V6 (Sold. I will miss her!) |
11-07-2023, 04:32 PM | #1266 |
Drives: 2020 Camaro LT1 Join Date: Feb 2020
https://www.thedrive.com/news/2025-r...range-extender
Look at that if I understood it right the V6 just charges the electric power train and you can just fill it with gas or charge it. I would personally just fill it with gas its faster. |
11-07-2023, 05:09 PM | #1267 | |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
(I don't think diesel/electric locomotives use charged batteries...They generate electricity straight to the wheel-driving electric motors. Could be wrong, dunno. It's a unique combo, but like all EVs, it's the answer to a question that never needed to be asked....lol. God help the early adopters on this one...lol Last edited by 90503; 11-07-2023 at 05:20 PM. |
11-07-2023, 05:34 PM | #1268 | |
Drives: Iron Lung, Jimmy Join Date: Jun 2009
The setup on this truck is, in my opinion, perfect. Most of the time you have an EV truck with gobs of power. Go on a trip, though, and there are no worries about range. And there is plenty of towing capacity even for the outlier who needs to pull 14,000 pounds. If it works as advertised I call it a home run. |
11-07-2023, 05:40 PM | #1269 | |
Drives: 2022 2SS 1LE Join Date: Dec 2021
11-07-2023, 05:42 PM | #1270 | |
Retired from GM
The Chevrolet Volt operated under the same principle. It was almost always driven by the electric motor. Even when the engine (one of the cheapest, lowest powered engines in the GM portfolio at the time) was running, it pretty much droned at mid-range rpm and charged the battery. The engine wasn’t powerful or efficient because it didn’t need to be.
11-07-2023, 05:49 PM | #1271 | |
Retired from GM
11-07-2023, 06:23 PM | #1272 | |
"Those 145 miles of battery range will likely drop to less than half that when towing, but the generator keeps the rig rolling after that. The generator in question is rated at 174 horsepower of continuous output. That doesn't sound like any way to keep up while towing 14,000 pounds, but a Ram powertrain engineer we spoke to says this is plenty. On generator power, you can cruise a flat interstate at 65 mph with a max load trailer until the fuel tank needs to be refilled. Tow something like 7000 pounds, and it only gets better. The ups and downs of rolling terrain are covered by dipping into the unused portion of the battery on the upslope, then shuffling some power back into the battery when easing off and regenerating on the downslope. If the load gets more intense, the system can run the generator up to its peak output of 255 horsepower. But there's always battery power standing behind that, so the occasional short bursts that need more power than that should always be possible. eaded for the mountains? Select Tow mode, and the charge-sustaining set-aside percentage is increased to 35 percent, up from the normal 16 percent. The V-6 engine and generator set will come online earlier, and the generator will run closer to peak output more of the time. Between that and the enlarged Tow mode battery reserve, Ram says the Ramcharger should be more than able to tackle the kind of long, steep grades found in the mountain West. That checks out, because we've towed up long western grades with EVs, and the upslopes don't last nearly as long as you imagine. Electricity use certainly spikes up, but we're not talking dozens of miles at a time with no letup. There are always ups and downs, and there's always more left at the summit than we expected. Here an engine and generator have your back, and you'll gain a lot back on the way down the other side." So, it does partially charge the battery as well, but not exclusively. Enough to supply some extra power if needed from the battery for a short burst. Last edited by 90503; 11-07-2023 at 06:51 PM. |
11-07-2023, 09:07 PM | #1273 |
Retired from GM
But the engine is not connected to a drivetrain. It is only connected to electric motor(s) and so the power drawn from the engine does not go directly to the wheels. It goes to the electric motor which can operate at their own power capacity.
11-07-2023, 09:14 PM | #1274 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Did we hit on this yet?
Well what do you know...https://www.yahoo.com/news/electric-...002712095.html "RAM is making...It's called the Ramcharger, a pickup that can travel 145 miles (235 kilometers) on electricity, with a 3.6-liter V6 gas-powered engine linked to a generator that can recharge the battery while the truck is moving."
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
