dave@hennessey
Old 09-11-2022, 06:22 PM   #15
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Originally Posted by Bee View Post
Yeah, its usually an o ring and/or the gasket where the lines go into the block. Here's a great thread with a link to a video (around 1:40 he shows the diagram with the parts he ordered).
https://www.camaro5.com/forums/showthread.php?t=446107
They are also known to leak coolant at the fittings that go into the oil cooler. I think GM started putting oil coolers in Vettes around 2008-2009, and have probably redesigned it since then...but 5th Gen Camaros are known for leaking. It's not a constant drip or anything, just enough to be annoying.
Along with gasket did he replace all 4 green seals (are the 4 seals part#22 even though only one is shown in the illustration?)
camguynj is offline   Reply With Quote
Old 09-11-2022, 08:44 PM   #16
Bee
Bee's Avatar
Drives: SS/RS - Rally Yellow
I assume he would have replaced all 4...if you pause the video at 2:01 it will show "Required: 04" on the screen. Or better yet, you can take morepowerjoe's word since he already went that route:
Originally Posted by morepowerjoe View Post
Yes I did change all the green o rings and gasket.
Check out my build here.
SEPA5 South Eastern Pennsylvania 5th Gen Camaro Club
Bee is offline   Reply With Quote
Old 09-12-2022, 04:09 AM   #17
camguynj
camguynj's Avatar
Thanks very much for clarifying! Because the illustration only showed one instead of all 4 is why I asked. I wonder if he ever had anymore leakage?
Old 09-12-2022, 04:14 AM   #18
camguynj
camguynj's Avatar
Did you have anymore leakage after you changed them?
Old 09-12-2022, 04:23 AM   #19
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
YES I did! It really sucked to go through all that and still have a leak. But one thing I read though people say that it leaks through the factory plug or something like that on the cooler.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 03-19-2024, 02:57 AM   #20
GenesisCoupe
Drives: 2011 Chevy Camaro 2SS A/T
Have you noticed an increase in oil temperature when driving hard without the oil cooler ?
GenesisCoupe is offline   Reply With Quote
Old 03-19-2024, 03:09 AM   #21
morepowerjoe
Well I actually replaced mine with the mishimoto oil cooler. It seems like the oil cooler dropped my water temp a little though by not using the radiator to cool the oil and my oil temp now doesn't go over 217* unless I'm getting on it for a while.
Old 03-19-2024, 03:45 AM   #22
GenesisCoupe
I read that many people delete the oil cooler and install plugs. Will the oil overheat in this case? I mean with the standart radiator
Old 03-19-2024, 04:41 AM   #23
morepowerjoe
I don't think that it will raise your temp too much as long as your just dd, but any more then that I wouldn't really know.
Old 03-20-2024, 07:05 PM   #24
Bee
Bee's Avatar
I ended up deleting my oil cooler last year using the Improved Racing Kit. I haven't seen any new oil drops on the garage floor. I don't have a manual oil temp gauge but my coolant temps haven't changed.
The only thing I am a bit more mindful of now is I will let the car warm up a little longer in the driveway before heading out.
