09-23-2019, 04:11 PM | #1 |
~COTW 6/30/14~
I need a special COPO hood
Does anyone know where I can find one that is metal that I can paint to body match and can accept the factory hood liner? I would like a COPO hood and still be able to display my liner.
Mods: Heritage Grill, Blade Spoiler, Corrado Hoodliner Mural, Premium Engine Boxes, Radiator Shroud, Custom Painted Bowties, Dipstick & Engine Caps, RX Catch Can, Corsa cat back exhaust, CAI black powder coat cold air, Apex cold air intake scoop and Apex washer tank relocate kit, Dynatech SuperMAXX Ceramic Coated LT Headers, High Flow Cats, JRE470 Rough Idle Cam Package, DSS 1,000 RWHP Axels, Slowhawk Mustang Dyno Tune, QTP QTEC 66 Low Profile Cutouts and iTSX. 453 RWHP 427 RWTQ
WEB LINKS BUILD TIMING CHAIN FAILURE TRANSITION FROM STOCK TO CAM VID |
09-23-2019, 05:56 PM | #2 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
I don't recall ever seeing a metal Copo hood, not sure if anyone makes one
09-23-2019, 06:14 PM | #3 |
~COTW 6/30/14~
I could do fiberglass. The important point is the hoodliner.
09-23-2019, 06:28 PM | #4 |
I had a VCN fiberglass hood on mine, if I remember right it had an inner shell that was similar to a stock hood so you could most likely use your hood liner. I would think other "street" hoods will have a similar shell. If not you could add mounts for your liner, it's not hard to do with fiberglass.
09-24-2019, 11:46 AM | #5 |
~COTW 6/30/14~
Thanks
09-24-2019, 01:01 PM | #6 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
VFN...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
09-24-2019, 01:39 PM | #7 |
Drives: 2010 Cyber Gray LS3 SS/RS Join Date: Jul 2017
I can pop the hood and snag a pic of the underside of my Harwood 5”, can’t remember what it looks like.
2010 Cyber Gray LS3-BTR stage 4-480/428 RXT and 3.91’s
09-24-2019, 03:58 PM | #8 |
09-25-2019, 04:05 AM | #9 |
BOHIC
Drives: 2010 Camaro SS "Enola" Join Date: Jun 2014
Vfn copo style hood
What else can I do to my Camaro?
09-25-2019, 06:42 AM | #10 |
~COTW 6/30/14~
So there is what looks like an OEM felt liner under your hood? I emailed VFN asking. Im assuming they can be painted to body match with out paint quality issues?
Tico, do you have hood down pics?
WEB LINKS BUILD TIMING CHAIN FAILURE TRANSITION FROM STOCK TO CAM VID Last edited by Maxspeed; 09-25-2019 at 07:01 AM. |
09-25-2019, 10:25 AM | #11 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
look in his garage
10-19-2019, 02:45 PM | #12 |
BOHIC
No there's no liner, it's all fiberglass
