Old 01-24-2018, 04:33 PM   #1
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Guesses on my numbers
Well finally after 2+ years of work getting my car tuned in the next month curious as to everyones take / guess on finished numbers
Build is
ERL 427 Superdeck 6 all forged 9.5:1 compression
PRC 255 6 bolt heads with 1/2 inch head studs
Johnson linkbar lifters
Pat G spec Blower cam 224/244 .626 .626 114+4 LSA
Sniper low pro intake
NW 102mm TB
ID 1700 injectors
Squash dual 450lph fuel system w/ flex fuel kit on E-85
F1A Procharger maxed out with a 3.85 pulley (should make between 15-17lbs) and 1300hp intercooler
M6 pushing to 3.45 gears
What do you think the RWHP will be?
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 01-24-2018, 06:07 PM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
...obvious $$$ build so I would say/hope 1027/971 not sure with the E85..that is one area I am workin on...either way a SH!T load of fun OP...post vids!
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 01-24-2018, 07:15 PM   #3
QUICRNU
Drives: Z06 wannabe
Id like to see more like 1200 on this one...but im a 600ish guy, so i dont know.
Apex Focused
QUICRNU is offline   Reply With Quote
Old 01-24-2018, 07:55 PM   #4
Bildo
Bildo's Avatar
I think when / if I upgrade to a F1X 4 digits is possible but not with a standard F1A maybe 815-830 is what I am hoping for, always happy with more. The F1A is small for the motor and the compression is a bit low for E-85 as I originally planned pump gas and meth when I ordered the shortblock but plans evolved and changed over 2 years.
Old 01-24-2018, 08:30 PM   #5
ecreps
Drives: 2014 1LE, 1996 z28
860/840 is my guess
ecreps is offline   Reply With Quote
Old 01-24-2018, 09:17 PM   #6
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
< 1k rwhp. 6 bolts heads and 9.5:1 compression needs 27 psi, not 17. Step it up.
Unavowed is offline   Reply With Quote
Old 01-25-2018, 04:27 AM   #7
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
it's a stick car and 427 cubes.
limiting factor will be blower
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 01-25-2018, 07:39 AM   #8
AGP Turbo
Drives: All things Turbocharged
920whp
Do we win a t-shirt?
AGP Turbo is offline   Reply With Quote
Old 01-25-2018, 08:30 AM   #9
Bildo
Bildo's Avatar
Originally Posted by AGP Turbo View Post
920whp
LOL if you hit it I will have one made
Old 01-25-2018, 08:45 AM   #10
frankwjr
frankwjr's Avatar
forgot to ask..what's max rpm? with that cam at least 7k? that's what I was basing my "guess" on...
Old 01-25-2018, 09:23 AM   #11
Bildo
Bildo's Avatar
I am probably going to put the limiter on 6900 it should be able to handle 7k but I will be slightly over spinning the blower at 6900 with a 3.85 pulley.
F1A max impeller rpm is 74000
6900 Engine RPM = 74036 impeller rpm
7000 Engine RPM = 75109 impeller rpm
Old 01-25-2018, 09:39 AM   #12
CGbambam
Drives: 2011 Camaro 2SS
1150rwhp
CGbambam is offline   Reply With Quote
Old 01-25-2018, 10:26 AM   #13
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Bruh, with all the bling you have in that engine, it would be a crime to go with anything less than the F-1X. Mine made 1050 ish at 17.5 psi (without the restrictor) . . . just saying, on the smallest bottom pulley no less.
That said I am guessing you will be in the 850-875 hp range.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 01-25-2018, 10:33 AM   #14
hillshooter
Drives: 2015 Camaro SS commemorative
899hp
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
