04-24-2015, 08:00 AM | #15 | |
Drives: 2021 300 Join Date: Jan 2015
04-24-2015, 08:17 AM | #16 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
All a recalibration does is change priorities around. GM is balancing durability, hot and cold weather performance, FE, emissions all to get the best overall package. If you don't care about durability then of course you can make more HP. OEMs spend years of dyno and prototype testing assuring that an engine will start and perform and meet emissions at 12,000 feet and -40 all the way to Death Valley at well over 100 degrees. And two weeks after launch you think an aftermarket guy considered and tested for all of that? Of course not. So this where the copyright issue comes in to play. Taking OEM programming and modifying it and then selling that for a profit. GM already prohibits modifying the PCM by voiding the power train warranty if you do.
04-24-2015, 08:23 AM | #17 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
The Bird is the word! |
04-24-2015, 09:23 AM | #18 |
Don't that is accurate. They could void the warranty on the PCM directly or if they prove your tune caused a part to fail then void that, but they can't say your tune caused the water pump to leak or something obvious like that.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
04-24-2015, 09:49 AM | #19 | |
If the work being done requires your dealer to submit the snapshot for warranty approval you would be SOL. Not sure if a water pump or hose falls into that classification.
04-24-2015, 10:17 AM | #20 | |
Now is it worth the hassle, that's another story. There are definitely horror stories out there of people going months without their car and long legal battles.
04-24-2015, 11:52 AM | #21 | |
Drives: Really Slow Join Date: Apr 2010
also, the people that tune their cars, are usually full aware they are tossing their warranty out the window, but just don't care.
04-24-2015, 12:15 PM | #22 | |
Now if I kill the transmission by disabling torque management or something, they can certainly void the repair and I would have to prove it was not caused by my modification and would be unlikely to win. But warranties cannot be summarily dismissed in entirety.
04-24-2015, 12:31 PM | #23 | |
04-24-2015, 12:36 PM | #24 |
another example, if you swap out your intake filter with an aftermarket (that's not GM approved), but leave the rest of the intake stock, the whole intake system will be void. at least that would be my understanding.
04-24-2015, 12:47 PM | #25 |
Let me give you a first hand example. My previous car had an APR tune which added quite a bit of power over stock. I had the tune for almost 30k miles and the dealer techs knew it because we had talked about it in the past. VW has the same policy as GM about ECU tuning. At 43k I started getting a service light. I looked up the code and it was due to a clogged intake valves. I did some searching and found a TSB (technical service bulletin) regarding the issue was an actual defect from the factory and would require a new intake manifold. I also had a CAI on the car. I went to the dealer, they checked the logs, started to act like they would charge for it then when they saw the TSB immediately advised it would be covered. Point in case, defects trump everything if the warranty is in place. The dealer could have easily said my CAI or tune resulted in the issue, but I could prove legally that the issue occurred in factory cars as well due to the TSB.
I think bottom line we can look at this way, the majority of people who have tunes will never see/report an issue to a dealer caused by a tune. If they do, there is a definite chance of the dealer not honoring the repair warranty, but that dealer will have to provide a written reason as to why they are denying the claim. This could be appealed if you can prove your modifications are not the cause of your claim. But any modification of a vehicle is treated the same way, there is no wording in the law to grant ECUs/PCMs special circumstances. The manufactures simply state what they do because they want to ensure they are covered, because of the wide range of impacts tuning can cause to the powertrain.
04-24-2015, 10:19 PM | #26 | |
So it doesn't matter what you prove it matters what GM states the warranty policy is.
04-25-2015, 08:42 AM | #27 |
The MM act was supposed to protect owners from having to use the manufacturers factory replacement parts instead of using aftermarket replacement parts. What that means is like you can use a Fram oil or air filter instead of the GM version and they cannot deny warranty coverage in case you have a oil related failure unless they can prove the part you used was the cause of the failure.
It was never intended to be used for performance parts but only replacement parts, but since those were not specifically excluded performance parts manufacturers say their parts are covered by the MM act. It's a gray area in my opinion on the performance parts aspect and it much easier on the manufacturers part to deny coverage due to performance parts. Anyway they can only deny coverage for the related parts that are affected by the performance part. If you have a supercharger installed they cannot deny coverage for a bad power window motor, or a faulty heated seat because they can not be affected by the supercharger.
04-25-2015, 08:49 AM | #28 | |
Drives: 2010 rs 2lt Join Date: Aug 2012
"This means if you want to modify your car by getting your ECU flashed to make changes to, say, increase horsepower, change throttle response, or whatever, you’re violating the law, even if you don’t touch any of the safety or security code in the car’s computers. " This whole thing is wrong in so many ways, and if the automakers are allowed to restrict owner access to their own cars — whether they themselves tinker or repair them or not — a cascade of unfortunate effects will follow. Independent repair shops will have it especially rough, becoming vulnerable to manufacturer lawsuits if they attempt to repair a car by accessing the ‘restricted’ code or even just connecting to the ECU. I’m a firm believer that if you can’t open it, you don’t really own it. I believe in things like Mister Jalopy’s Maker’s Bill of Rights, and I firmly believe that everyone who owns a car has the right to work on their car. If a manufacturer wants to void a warranty, fine. That’s the risk we take. If they want to make safety and emissions modifications harder to do — but still accessible for independent repair shops to work with — okay. Hell, if they even want to stop selling cars entirely and just lease cars with the understanding that the driver doesn’t truly own the vehicle, they’re free to do that, too. But if I buy a car, I should always be free to fix or modify that car, even if it’s a terrible idea that gets me 20 HP and 11 MPG. It doesn’t matter — it’s my car. The last thing we really need is another "Law" about this |
