Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 10-25-2016, 09:41 PM   #1
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
FS: Fabberge V6 Twin Turbo Kit
I'm selling my bolt on Fabberge V6 twin turbo kit for the V6 LFX engine Camaro. Prior to trading in the car I removed the kit. I am selling it with the dual A pillar pod and gauges.
PRICE DROP:$4,250 Shipped to the continental US.
• Garrett GT28 Journal Bearing Turbos
• TIG-welded 304 Stainless-steel Mid Pipes
• 2.5” TIG-welded 304 Stainless-steel Downpipes
• ATP Internal Wastegates
• TiaL “Q” Black Blow-Off Valve
• 3” Aluminum Bar & Plate FMIC Core
• Aluminum Intercooler Deflector Shield
• Setrab Oil Return Pump & Bracket
• Oil Feed & Return Line - Fragola “Soft” Nylon Braided Hose & Black Fittings
• 3” 6061 Aluminum Intercooler Tubing
• 3” 6061 polished Aluminum Charge-pipe
• K&N Filters
• Lower Skid-plate
• Relocated windshield Washer Bottle
• Oil Cap Separator
• RX Dual Check Valve Polished Catch Can Setup
• NGK LTR7IX-11 Iridium spark plugs
• Dual A pillar gauge pod
• AEM Tru Boost electronic boost controller
• Cobalt wideband AFR gauge
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 10-26-2016, 08:44 PM   #2
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
how many miles did you put on the kit?
Tmick5jr is offline   Reply With Quote
Old 10-26-2016, 10:03 PM   #3
HP Turbine
Boosted
HP Turbine's Avatar
It was just over 20k.
Old 11-06-2016, 09:17 PM   #4
HP Turbine
Boosted
HP Turbine's Avatar
Bump for winter project time.
Old 11-18-2016, 05:24 AM   #5
HP Turbine
Boosted
HP Turbine's Avatar
Bump
Old 11-28-2016, 08:49 AM   #6
d_jensen35
d_jensen35's Avatar
Drives: 2015 Camaro 2LT/RS
I'm interested, I sent you a pm
d_jensen35 is offline   Reply With Quote
Old 12-06-2016, 12:07 PM   #7
d_jensen35
d_jensen35's Avatar
Still very interested, please get back with me.
Thanks
Old 12-06-2016, 04:21 PM   #8
bleavens1962
Drives: 2014 1LS Camaro
How is this not sold yet ?
bleavens1962 is offline   Reply With Quote
Old 12-19-2016, 01:28 AM   #9
HP Turbine
Boosted
HP Turbine's Avatar
PRICE DROP. $4250 shipped to the continental US.
Old 12-21-2016, 11:01 AM   #10
eoseitz
Drives: 2014 Camaro 1LT
How well would this work with the overkill e85 kit installed? I've heard there are issues with e85 and forced induction on the LFX's.
eoseitz is offline   Reply With Quote
Old 12-21-2016, 07:00 PM   #11
HP Turbine
Boosted
HP Turbine's Avatar
I haven't done any research on the e85 kits. So i don't exactly know its compatibility.
Old 12-21-2016, 08:03 PM   #12
djcolopi
djcolopi's Avatar
Drives: @orange_maro
HPFP is a limiting factor on the LFX build. Depending on setup and tuning you will run out of fuel around 450-510rwhp on pump gas. E85 requires 30% more fuel so you will run out of fuel with a lot less power. I am running out of fuel now and pushing 520+rwhp on pump gas.
Since its a flex fuel setup you would be fine on pump gas, just can't fill up with E85 till we figure out a solution.
Instagram @orange_maro_
djcolopi is offline   Reply With Quote
Old 01-03-2017, 04:50 PM   #13
HP Turbine
Boosted
HP Turbine's Avatar
Bump!
Old 01-15-2017, 10:36 PM   #14
HP Turbine
Boosted
HP Turbine's Avatar
Bump!
