04-15-2015, 02:52 PM | #85 | ||
Drives: 21 Bronco Join Date: Jun 2012
But BC the magazines got fully loaded mustangs for reviews, they came in on the heavy side at over 3800 pounds. For some reason everyone wants to use the 3800 pound weight Quote:
Agreed, but the 1LE is lighter than a 1SS apparently. |
04-15-2015, 03:12 PM | #86 | |
Drives: 97Z,02TA Join Date: Mar 2011
http://m.motortrend.com/roadtests/co...t8_comparison/ |
04-15-2015, 03:14 PM | #87 | |
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
04-15-2015, 06:46 PM | #88 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
17% for DI alone? Maybe in certain cases. But not likely. It is a nice bump, BUT if it was so easy everyone would just do it wouldn't they? Yes, it's a 200 psi fuel system and there is cost, but if it were a simple 17%, the Coyote would already have it. In fact, just put the DI engine in the 350R and call it a day.
04-15-2015, 10:18 PM | #89 |
Drives: RS Join Date: Jan 2013
04-15-2015, 10:35 PM | #90 |
I thought I read 17%. Here is a link to the article anyway. http://www.hotrod.com/how-to/engine/...ect-injection/ |
04-16-2015, 01:08 AM | #91 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
"Ford’s fuel-metering expert Scott A. Lehto says the ’10 Focus was “rated at 140 hp and 136 lb-ft at 10:1 compression. Our ’13 DI Focus 2.0L has 160 hp and 146 lb-ft running at 12:1 compression on 87-octane gas.” That’s a 14 and 7 percent gain in power and torque, respectively."
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
04-16-2015, 09:17 AM | #92 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
I think the 3.6 DI LLT is almost the same as the 3.6 non DI LY7. I think there is almost a 50HP difference. However I think it greatly depends on the engine and how efficient it was to begin with. The Coyote gaining over 50 HP with DI and no other changes is way overly optimistic. I do think when GM finally taps out the LT1 it will be at around 480HP. Tune only results from the LT1 tell me GM went pretty conservative for future power bumps.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
04-16-2015, 09:55 AM | #93 |
Drives: 99z28 with bolt-ons and a mwc fab 9 Join Date: Jul 2012
I think some people forget that along with more power from di you also are able to run a lower grade gas "with higher compression vs reg. Injection" which saves a few bucks.
I like my woman like my milk shakes, THICK!!!!
04-16-2015, 10:29 AM | #94 | ||
Either way the camaro is shedding weight, mustang going to have to have something up their sleeve |
04-16-2015, 10:35 AM | #95 |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
DI by itself won't add 30hp/30tq to the 5.0, keep dreaming. Just like the dreams of a 2-300lb lighter Mustang it just won't happen. 10-15hp and 30tq, sure. Or 30hp, 10-15tq.
Obviously they may make other changes as well. DI will also add about...30-40lbs? |
04-16-2015, 01:30 PM | #96 |
I honestly think it would be a huge waste of potential if Ford added DI to the current engine and made no changes to cams, valves, pistons ect. They are going to want more compression minimum and that likely means new pistons. I think your probably correct in that it won't add as much torque as it does HP. I don't think DI by itself adds that much weight from the new fuel components but could be wrong. If your basing that on the LT1 its because of DI AND VVT/AFM.
04-19-2015, 09:51 AM | #97 |
Drives: suzuki Join Date: Apr 2015
04-26-2015, 01:18 AM | #98 | |||||||
Drives: Silverado Join Date: Feb 2015
Because: not really a Mustang transmission. Quote:
