Old 12-13-2014, 11:30 PM   #1
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Upgrading the oil pump, anything else to consider?
I'm planning to upgrade to the Melling oil pump and a baffled pan. What else is recommended to upgrade while I have the timing chain cover off? Seems like a lot of work to not upgrade more while it's all apart.
Thanks.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 12-13-2014, 11:33 PM   #2
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Sounds like its time for a new cam while you doing this. Other wise I would recommend a Katech C5R timing chain.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 12-14-2014, 11:44 AM   #3
Avalnch
Avalnch's Avatar
Thanks for the info. The timing chain was my first thought. I see on JDP's website that they also sell an RSH block and 3-bolt conversion kit. Do either of these apply to what I'm doing?
Old 12-14-2014, 02:16 PM   #4
Birm
Birm's Avatar
Drives: Florida Speed & Power
Timing Chain, UDP, Cam
Birm is offline   Reply With Quote
