dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 01-15-2015, 09:37 AM   #1
JBT
Drives: Camaro
New Hoosier 325/45R18 dot drag radial.
They're now available for purchase for $265 each + shipping.
Here's the specs:
http://www.hoosiertire.com/pdfs/pbDOTDragRadial.pdf
JBT is offline   Reply With Quote
Old 01-15-2015, 05:11 PM   #2
striker1703
striker
striker1703's Avatar
Drives: 2010 Camaro 2SS
nice another option for 18"s
striker1703 is offline   Reply With Quote
Old 01-15-2015, 07:58 PM   #3
white ZL1
Drives: none
What do we need a 30" tall tire for?
white ZL1 is offline   Reply With Quote
Old 01-15-2015, 11:25 PM   #4
JBT
Drives: Camaro
It's simply there if you need it. Having more options is always nice.
Old 01-17-2015, 03:18 AM   #5
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
A 29" 325\40R18 would be nice.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 01-18-2015, 09:20 AM   #6
Unreal
Drives: 2006 Z06
Is a 30" tire going to fit on any of these cars? I know there is no way that is fitting a vette.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 01-28-2015, 11:36 AM   #7
linehand7
Drives: 03 duramax 01impala 2010 2ssrs
Mine actually measured 29" and they hook great, and they have about 5"s of side wall, I had them last summer on 600 hp, this spring i'll have them on 800hp - 1200hp
linehand7 is offline   Reply With Quote
Old 01-28-2015, 12:23 PM   #8
62nalide
62nalide's Avatar
Drives: 2013 SS
That's good for a truck project I have going on!
62nalide is offline   Reply With Quote
Old 01-28-2015, 03:23 PM   #9
VADER SS L99
Might be good for someone who runs out of gear at the track and doesn't want to change the gear ratio again. Even then that's alot of rolling weight/resistance.
Old 01-29-2015, 02:07 PM   #10
linehand7
big horsepower= big tire, or you can spend all you money on a 15" conversion and then fill the wheel-well with great big 15" tires, got a problem hooking up? these will do the trick and yes I row the gears and yes I drag race, sorry but these tires work. what's with all the negativity? ... linehand7 2013 and 2014 Oahe speedway Street/Trophy champion... you want to win races? hook and go... nuff said...
Old 01-29-2015, 02:12 PM   #11
linehand7
if you go to a 325/40/18 you are missing the point you need more sidewall to get the bite and like I said before mine weren't 30" tall.
Old 01-29-2015, 11:08 PM   #12
JD_Alaska
JD_Alaska's Avatar
Drives: 2013 Camaro SS Coupe L99
So if you miss the point at 325/45R18 what makes you hit the point?
JD_Alaska is offline   Reply With Quote
Old 01-30-2015, 10:04 AM   #13
linehand7
this is why I've been a member since feb 2009 andonly have 135 posts, everybody bashing each other, all i'm saying is hoosier sent me a set of these tires for research and development and if you want an 18" tire ( 18" corvette rims are cheap) and you plan on using it at the track, these are awesome! two time track champion... linehand7
Old 04-14-2016, 03:28 AM   #14
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Here
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
