04-23-2016, 12:37 PM | #1 |
Drives: 14 1LE Join Date: Jul 2013
STOCK T-STAT VS 160 FOR ECS KIT
i kind of lean towards just keeping the stock t-stat on when i get my ECS kit installed.. anyone with experience here?
04-23-2016, 12:57 PM | #2 |
Drives: 2014 1LE, 1996 z28 Join Date: May 2015
It shouldn't really make much difference either way.
04-23-2016, 01:33 PM | #3 |
i just read that your car wont get up to it's efficient temperature that the engine was designed around with a 160 degree tstat, causing more engine ware over time.
04-25-2016, 09:04 AM | #4 |
Drives: 2011 Camaro 2ss M6 Join Date: Mar 2012
Mine stays around 180-190 with the 160 thermostat
04-25-2016, 09:27 AM | #5 |
For Drag race applications we are now carrying LPE 174 stats, a better choice to get the temp up to the desired 185 quicker.
The Fan settings and Radiator are responsible for operating temp after the car is warmed up. The T-stat is there to get it up to temp as quick as possible to prevent wear. Ted.
www.jannettyracing.com
04-25-2016, 10:11 PM | #6 |
i was told that the oil needs to get up to 205 so the moisture gets cleared out of the system.
04-26-2016, 08:37 AM | #7 |
Drives: 2006 Z06 Join Date: Oct 2010
That is oil temps, not water temp. That being said, a proper sized t-stat will get the oil there much faster. With a low t-stat it can take 20+ minutes of driving just to get the car warm enough to beat on.
Nick
Corvette Z06 -1200ish rwhp |
