Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 02-16-2016, 11:49 AM   #1
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
Drives: 2011 2LTRS Convertible
Is this an important Motor Oil quality?
Interesting comparison of motor oils at low temperatures.
I bowl. Drive around. The occasional acid flashback.
Mr. Stacy is offline   Reply With Quote
Old 02-16-2016, 12:02 PM   #2
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
That was interesting. I'd like to see those same guys do a high temp test. I've been using Mobile 1 in my vehicles for a long time. I won't be changing.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 02-16-2016, 12:20 PM   #3
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
I've been using Pennzoil Ultra and if you believe the propaganda it is the number one oil out there by a long shot. I will say it does an incredible job keeping the engine spotless.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 02-16-2016, 12:53 PM   #4
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
Then again, different tests, different results. Look at these bearing tests:
http://www.animegame.com/cars/Oil%20Tests.pdf
Shocking to say the least.
Which testing sites and results are people using to arrive at their overwhelming support of Aimsoil?
Old 02-16-2016, 02:53 PM   #5
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
AMSOil has been proven for years. There's a good bit of data to back it up out there. That being said, any oil that meets GM's listed specs for your car (and some that don't say because they haven't gotten licensed for the spec) will work fine for the majority of the drivers here.
Oil is one of those topics that's like religion and politics. If you want your fill of the hoopla head on over to http://www.bobistheoilguy.com/forums...s.php?ubb=cfrm
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 02-16-2016, 03:15 PM   #6
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
See, that's what I thought. But then I found out the Walmart brand is desox1 certified and labeled. Then I see a video like the one above and I think, ok sure, that's at 40 below... probably not an issue, but still...
And the bearing tests? Those are HUGE differences between the worst and the best...
I know... I'll have to just pick a couple and stick with them.. Funny how I didn't care too much about it before I got my Camaro. Or I should say, before I got a little education on the subject.
Old 02-16-2016, 03:56 PM   #7
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Important if you lived in Antarctica...Truth is, an engine running any of those oils would need a block heater in those conditions. The debate over "the best oil out there" is never ending. I was a Mobil 1 guy for years, just switched to RP out of curiosity mainly. I maintain my car on a "severe duty" schedule, and have never had a major engine issue in over 40 years of driving....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
