03-06-2020, 01:04 PM | #1 |
Drives: 2015 ZL1 Join Date: Feb 2020
Do you use 5w30 or 0w40 ?
Just picked up my ZL1. About 2.5k miles from my first oil change (as I change every 3-4K and it was just changed when I bought it) .
But been doing research. I’ve heard good things about both 5w30 and 0w40. Wanting to use M1 as it’s readily available and what the dealer uses. I keep seeing mixed answers on “use 5w30 because that’s what the manual says to use” and people swearing by 0w40 for protection and good oil pressure. Are there any benefits to using one or the other? I live in the south so real hot summers. Not to cold of winters. I’ve seen M1 0w40 has closer viscosity to 5w30 with a lot more additives for protection. I also plan to be H/I/E , pulley, tuned, injectors. Etc. So it won’t be some 1k + RWHP. But won’t be no slouch either. I used 0w40 in my 370z (it was known for hot oil temps and breaking down without an oil cooler, I ran 0w40 in it and had good results) To the oil gurus out there, Would 5w30 or 0w40 be better for my setup? Also what oils do you guys use? |
03-06-2020, 02:07 PM | #2 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Penz ultra plat 5-30 around town
Amsoil Dominator Race Oil 15-50 at the track |
03-06-2020, 03:11 PM | #3 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I'm not a guru. I prefer to give broad answers sometimes for other people and situations being included. I'd go full synthetic and not 0-20 unless in a super cold climate nor 10 40 unless in Vegas summer city driving or something.
That being said on cars with variable valve timing and cylinder deactivation (not the ZL1) it's more important to stay close to what the OEM dictates or it might throw codes. |
03-06-2020, 03:17 PM | #4 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
Winter 0W-30
Summer 10w-40
GJDM |
03-06-2020, 03:43 PM | #5 |
03-06-2020, 03:45 PM | #6 | |
0w for winter to protect during cold start ups I’m assuming ? |
03-06-2020, 06:11 PM | #7 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
I started running Mobil 1 0W-40 5 years ago when I swapped cams. The additive package is definitely better compared to their standard 5W-30. I think it's especially helpful when you run E85 on a regular basis.
03-06-2020, 07:08 PM | #8 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I ran 5w30 M1 before cam, and now Redline 5w30 after cam (which is higher measured viscosity than M1 of same weight)
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
03-06-2020, 08:43 PM | #9 |
It don’t come easy.
Amsoil 5w30. Spring to fall.
03-06-2020, 09:11 PM | #10 | ||
Thanks for the input! I was hoping to get something more readily available that’s still quality stuff. Who’s got the fastest shipping I can order from? |
03-06-2020, 09:56 PM | #11 | ||
fo'shizZL1
03-06-2020, 10:57 PM | #12 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
15w50
03-07-2020, 08:12 AM | #13 |
Drives: 2012 ZL1 Join Date: May 2017
I use Driven LS on recommendation from Hutter Racing. They seem to think its as good as it gets for my application.
www.drivenracingoil.com/ls30-5w-30-synthetic-street-performance-oil.html |
03-07-2020, 09:38 AM | #14 |
Team 913
I like changing my oil for some reason ... Ive probably done 10+ oil changes in 14k mi ... haha ... 2 tranny changes and 2 rear end gear oil changes.
Track time and E85 life |
