09-02-2015, 05:36 PM | #1 |
Drives: Black 2015 Camaro Join Date: Dec 2014
Oil Consumption- Chevy Boning me
I have a 2015 v6 LS Camaro, I have put an injen CAI and the MRTV 1 axel back. I've been consuming about a quart every 150 miles and chevy says that it is because of the after market parts and they are flagging my car for oil consumption. Can anybody weigh in on this, Thanks.
2015 Black LS Camaro- MRT V1, ZL1 Diffuser, 4in Quad Tips, z28 spoiler, injen intake
09-02-2015, 05:38 PM | #2 |
Drives: 2014 2SS/RS Camaro Join Date: Dec 2014
That's hogwash. Put the stock airbox back on it and go to a different dealer.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH |
09-02-2015, 05:40 PM | #3 |
Cant they flagged it, so any dealership sees that now
09-02-2015, 05:45 PM | #4 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
That's BS
Pity a man in familiar places, who yet feels like a stranger.
09-02-2015, 05:45 PM | #5 |
Would rather be riding
Drives: No car no more Join Date: Jul 2009
Did you install your CAI correctly?
I'd call corporate, f&*k that dealer.
No dog in this fight anymore.
5th Gen owner 2009-2016. |
09-02-2015, 05:46 PM | #6 |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
Make them prove that the mods you have done are in fact the culprit. Unless they can prove it, they have to fix under warranty
09-02-2015, 05:51 PM | #7 |
You can sue them, they have to prove the mods caused the failure.
Look up The Magnuson–Moss Warranty Act. They can't prove their case because they haven't torn down the engine to determine what is wrong with it...... So they really don't know.
09-02-2015, 05:54 PM | #8 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Now if your CAI was installed incorrectly somehow as to allow extra air into the engine and cause it to run lean... then yeah, maybe they'd have a chance.
Put your stock airbox back on, see if it still burns oil. If it does, take it back in to another dealership.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
09-02-2015, 05:59 PM | #9 |
yes the cai is installed correctly
09-02-2015, 06:02 PM | #10 |
Drives: 2015 2SS Red Hot Adrenaline Join Date: Apr 2014
Even if lean a quart every 150 miles is crazy.
2015 2SS Red Hot Adrenaline |
09-02-2015, 06:04 PM | #11 |
Ed
Drives: 2013 AGM Camaro 2SS/RS/1LE Join Date: Dec 2012
Take it to a different dealer have them do a leak down test and pin point the issue. Likely either rings or valve seals are the problem, neither of which your aftermarket parts could cause to fail.
09-02-2015, 06:04 PM | #12 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Is it leaking it or burning it? If it's burning it,it should look like a locomotive. Either should be covered.. Seems like K&N says something to the effect that there CAIs doesn't void the warranty.Might try getting something from Injen in writing.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
09-02-2015, 06:06 PM | #13 |
Drives: 11' RJT 2SS/RS L99 Join Date: Jun 2014
Would it be the dealers responsibility to prove the after market part caused the problem or would he have to prove that the after market part did not cause the problem.
GPI VVT3 Cam
Circle D 3800 Single Disc Stall 1LE 3.91s Stainless Power Headers w/cats Fluidampr 25% UDP Cold Air Inductions Intake Bo White Ported Throttle Body ADM Trans Cooler Some BMR Goodies |
09-02-2015, 06:09 PM | #14 |
Tags |
camaro, chevy, consumption, oil |
