Old 01-26-2014, 11:53 PM   #1
caper
Drives: 2010 IOM 2ss/RS
was on it a bit and check engine light starts blinking along with stabilitrack
the lights went out within a couple seconds but I still pulled 4 codes
p013e
p013f both from no cats I suppose...but I also got
p0300 random misfire
p0502 vehicle speed sensor a circuit low input
these 2 have me worried especially the misfire...any ideas?? I can tell you the car stalls a bit , the idle is rough in the tune, can be difficult to pull away at times.
I cleared the codes, just to see if they will return tomorrow...anything I should be lookin at in the meantime? car seems to run ok although I have noticed some hesitation doing 3rd gear WO pulls at times...it (like the code) is random...
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 01-27-2014, 12:10 AM   #2
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2019 ZL1 on Order
Could be a bad MAF sensor, I was having similar issues and that was one thing we were going to look at - mine turned out to be cat failure but you say you have no cats
Misfire could also be bad spark plug so worth checking them
Modern07 is offline   Reply With Quote
Old 01-27-2014, 12:14 AM   #3
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Sounds like a misfire to me. I had some misfiring issues, and the stabilitrak light is the red flag for that specific problem. Change to a warmer plug or have your tune tweaked. I swapped plugs and it remedied the problem.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 01-27-2014, 03:56 PM   #4
caper
Ok, So I'm Going To Change My Plugs, And Check wires, AWell As Look AtThe Catch Can SetUp For Vacuum Leaks. After That I'll Be Lost.
Any Ideas On The Other Code? I Did A search And Didn't Find Anything
Old 01-27-2014, 06:00 PM   #5
Slowhawk
Drives: 1999 Trans Am
Best is to have the tuner scan over the tune while driving and see if he see's any bad sensors. Thats the quickest to diagnos the proglem.
Slowhawk is offline   Reply With Quote
Old 01-28-2014, 05:52 PM   #6
Kelly@PCMofNC
Drives: 2010 RS/SS
p013e
If you aren't able to take the car back to the tuner for a quick diagnosis, I'd start by checking out the spark plugs - especially if you're having a rough idle and it's having trouble getting going!
Kelly@PCMofNC is offline   Reply With Quote
Old 01-29-2014, 11:14 PM   #7
caper
so plugs are changed, no issues with that wires or any vacuum leak that I seen. I haven't reset a code since I cleared them, but I just got back to WOT tonight after the plugs...the hesitation at WOT in 3rd is still there with what sounds like a bit of backfiring. 2nd gear sounds and pulls fine. still no code though. ill be trying to get it to my tuner soon. in the meantime I will be staying out of boost :( . any other ideas?
Old 01-30-2014, 05:53 AM   #8
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Original battery in the car? I started getting some weird codes and was advised to change the battery so I did and . . . no more codes. I know that sounds weird but it worked. Probably wouldn't explain your 3rd gear hesitation though if you havent changed the battery, it's about time anyway. Just sayin
GL on fix and please keep us posted.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 01-30-2014, 08:41 AM   #9
2SS45th
2SS45th's Avatar
Try turning all the lights on, then disconnecting the battery, it'll drain the system. Then turn everything off and hook the battery back up.
Old 02-19-2014, 09:01 PM   #10
caper
so I wanted to update this. after changing the plugs and not helping. I took it down to Cunningham and they took a look at it and determined I needed a set of FIC850 . so in they went, ive been into it since and no code, car runs better as well. also picked up a few ponies to 563 and a few mpg. not the cheapest fix but I am happy with the results.
Old 02-19-2014, 09:27 PM   #11
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
What were in it?
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 02-20-2014, 12:41 AM   #12
caper
the 62lb ones that came in the kit
