Vararam
Old 01-26-2014, 07:36 PM   #1
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Power level to switch from 4 to 6 bolt heads.
Going to see if the heads are salvageable. What ballpark power level limit (FW or RW) should you try to stay in before 4 bolts become an issue. Looking at just buying a 416-418 Shortblock. However if the head(s) are shot, going to have to spend the money anyway and probably just switch to 6 bolt and LSx Thanks
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 01-26-2014, 07:46 PM   #2
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
There are a lot different answers to that question. What kind of power are you making now, and what are you looking to go to? A lot of budget shortblocks will reuse the stock block, forcing you to stay with 4 bolts. But....you can use 1/2" studs which will have a lot of clamping force.
I recently bought 6-bolt heads to use on my stock block. However issues arose and I was going to 1/2" studs, but then decided for the extra money to go with the LSX
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 01-26-2014, 07:58 PM   #3
SSBUSDRVR
SSBUSDRVR's Avatar
Thanks. Was mid 600's until self destruction. probably somewhere around 750 rwhp or a little more if lucky. Block is shot.
Old 01-26-2014, 08:04 PM   #4
Chris82xx
Chris82xx's Avatar
It's really up to you at that point. I went 811 on the stock block and heads. If you want peace of mind, go LSX. If you want to save a few bucks, do the 1/2" head studs at minimum.
811RWHP/719RWTQ
Old 01-26-2014, 08:14 PM   #5
Supercharged SS
Drives: 2010 Camaro
http://paceperformance.com/i-1308917...ine-block.html
Look into these. They had them at their Camaro fest display. I was talked out of it when my engine blew in August. Seems like a very good option. I'll be relooking into these over next winter.
Supercharged SS is offline   Reply With Quote
Old 01-26-2014, 08:17 PM   #6
Motion427
Drives: 2010 2SS/RS Red Jewel L99
What would a guy use for an oil pan?
I'm not sure if the stock pan would work.It uses the older main caps.
Motion427 is offline   Reply With Quote
Old 01-26-2014, 08:19 PM   #7
Supercharged SS
Drives: 2010 Camaro
Pace has is worked out. I have no f'in clue. My department is finances , not tech support!
Old 01-26-2014, 08:23 PM   #8
Motion427
Just make sure you leave the keys so that I can take your hot rod for a spin in march.I'll test it for you since you don't know how to shift a T-400 yet.
Old 01-26-2014, 08:26 PM   #9
Supercharged SS
Drives: 2010 Camaro
To much power for you. I'll have Matt pull a few plug wires to help you out!
Old 01-26-2014, 08:30 PM   #10
Motion427
Wires or the ZR1 plugs?
Sorry,I had too......
Old 01-26-2014, 08:34 PM   #11
Supercharged SS
Drives: 2010 Camaro
I got 8's now. I'm all grown up.
Old 01-26-2014, 08:43 PM   #12
Chris82xx
Chris82xx's Avatar
Slow down there killer. Baby steps first.
811RWHP/719RWTQ
Old 01-26-2014, 08:53 PM   #13
Unreal
Drives: 2006 Z06
Depends on the heads and setup. I've seen 1100-1200rwhp on 4 bolt setups.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 01-26-2014, 09:27 PM   #14
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I've got several 1Krwhp dyno runs on a 4 bolt block but using 6 bolt heads (the extra bolts go unused). I did this because I know down the road I am getting a 6 bolt block. The heads also have a .750 thick deck.
Studs, LS9 gaskets, and tuning go a looong way in keeping your 4 bolt cylinders sealed.
It also depends on what you are going to be doing with the car. Events such as the Texas Mile or similar events such as racing in Mexico are harder on an engine than an 1/8 or 1/4 mile run because the engine is under a longer period of stress.
If you have the money, go with the 6 bolt set up. What are you forced induction plans?
