07-18-2013, 11:53 AM | #1 |
Drives: 2012 camaro ls/rs Join Date: Apr 2013
catch can install
i will be getting my catch can today in the mail so i think i am going to install it today with a friend. how hard of an install is it? and any tips or tricks? its the rx catch can
07-18-2013, 11:59 AM | #2 |
Drives: 2013 2LT/RS Summit White Join Date: Feb 2011
Very easy
15 mins double check that you don't switch the hoses
07-18-2013, 12:10 PM | #3 |
Drives: Chevys at the limit Join Date: Nov 2010
Yep it's a very easy install. If you do a search on here, you can find a few threads with pics and tips. We are always happy to help if you run into a snag as well.
Best regards, Tyler 888-308-6007 |
07-18-2013, 09:25 PM | #4 |
did you guys use the stock hoses? or purchase more, i didnt connect it tonight because it looked like i needed more hose
07-18-2013, 09:37 PM | #5 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
I used more hose, just be carefull on they way it connects, I heard people blowing out there rear seals.
Pics if you need them
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
07-18-2013, 09:41 PM | #6 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
Very simple install. Simply but a line and slip the hose on. But another thing to be certain is that the drain valve is closed. You can check this by placing your finger on the drain and if you feel any suction then its open if not then your good.
07-18-2013, 09:50 PM | #7 |
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28 Join Date: Nov 2011
JUST what I needed to read SOME PEOPLE have BLOWN out there rear SEALS!!!!!!! Now I know I'm not trying this Myself ???? YIKES <<<<
07-18-2013, 09:54 PM | #8 |
The only time this has happened is when people hook up the lines backwards and even then there are very few people this has happened to. I wouldn't worry to much about it. Both the Elite and Rx come with instructions while they are not the best they will guide you through it. And you can post up a picture on the forum when your done for us to verify for an extra safety measure
07-18-2013, 09:56 PM | #9 |
Chiquita
Nope I will find a seller and Installer at C5fest and have it done
07-18-2013, 11:02 PM | #10 |
where did you guys pick up the extra hose from? would i have to go to my dealer or can i just pick it up at an autozone or a home improvement store
07-18-2013, 11:05 PM | #11 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
Skip this one is a no brainer, you can pull this install off in half hour tops!
07-18-2013, 11:06 PM | #12 |
B.O.D. 02/16/10
O'Reilly's or any auto parts store. I had to go with blue hose the first go round because they didn't have black that day!!
07-19-2013, 10:44 AM | #13 |
thanks guys ill install it today, ill let you know how it goes!!
07-19-2013, 11:11 AM | #14 |
Drives: Mean ass V6 Join Date: Jul 2013
Ok dummy question here, What does a catch can do?
