05-02-2022, 03:57 PM | #1 |
Drives: 2010 2ss Join Date: Jan 2022
LSA conversion boost help
I’m doing an LSA conversion on my 2010 SS ls3 and a 2.75” upper pulley with the ls3 crank balancer. Has anyone done this same install and what boost does it make? Thanks.
05-03-2022, 01:26 PM | #2 |
#teamGPI
Drives: 2010 Camaro SS Join Date: Aug 2020
Not sure about the boost, but a stock LS3 crank balancer will not work, you need a balancer thats compatible with a supercharger, at least the AC delco one, part#12674581
05-03-2022, 02:05 PM | #3 |
Drives: 2010 Camaro SS Join Date: Dec 2006
I believe the LSA and LS3 balancers were a little different offset. Do a search here. You’ll get the info. But a stock LSA balancer would work well for you. Then you have things like the ATI balancer. All around better. But pricey and not necessary unless you’re going for an all out build.
05-03-2022, 02:13 PM | #4 |
I think my ADM Performance kit had me reuse the stock L99 balancer. I had to remove the crank bolt to drill for a pin, but don't remember pulling the balancer off.
05-04-2022, 01:17 PM | #5 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Depends on the pulley kit. If it’s the ADM kit with the pulley on the stock water pump, lS3 balancer is fine. IF it is the LSA pulley kit, you’ll need the LSA balancer or third party upgradeable version.
I’ve done both and currently have the LSA pulley kit where you only needed to do a bit of modification to the ac unit… - Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 05-04-2022 at 05:52 PM. |
05-05-2022, 05:05 PM | #6 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
I bought a ZL1 balancer off of the forum here, worked great with an LSX kit. I run around 7.8-8 psi boost with this setup.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
05-09-2022, 11:27 AM | #7 | |
It should make about 8 psi with the 2.75 upper and stock LS3 lower. Don't forget to upgrade the fuel pump and FSCM colder plugs, and good tuning. Ted.
www.jannettyracing.com
05-24-2022, 11:57 AM | #8 |
Instagram: Mr2Hard2See
Drives: 2011 2SS/ RS Join Date: Apr 2018
I have a ZL1 balancer if you want to switch. As stated above you can use the ls3 balancer because I’m using a ls3 balancer on my Lsa build and it works perfectly with Lsx innovations 6 rib lsa conversion brackets part #Bd17. My blower has a 2.55 upper pulley though and some additional fuel mods. Just a guess but I’d say you’ll be at 8 or 9 psi
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242 BTR dual springs pushrods lifters retainers etc Che bronze trunnion Ls3 timing/valley cover Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers |
Tags |
ls3 conversion, super charger |
