07-16-2022, 12:06 PM | #15 |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Are you sure traction control was not disabled, even by accident? When you disable traction control on our cars it will let you get a little more slip angle before Stability Control kicks in to straighten the car out by applying braking as needed at each wheel.
If you were in the default mode with all nannies enabled then you must have really hit a slick patch of road or something before traction control and stability control cut power. In fact, these systems may have actually saved you from a spin and you don't even know it since it happens so fast.
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
07-16-2022, 12:07 PM | #16 |
Wow not related but I always thought track really turned off most of the dynamic aspect of the mrc. Even on my 16 SS I had it in track less that 1% of the time I drove it. Have you ever blown a seal on a damper? Since the 1le I locked the suspension to tour!
07-16-2022, 12:15 PM | #17 | |
I prefer to leave my suspension mode tied to the drive mode I am in so you can just change it via the button as opposed to hard coding it in the menu. I do hard set my steering mode to tour though. As for the exhaust mode, I pulled the fuse the day I bought it.
07-16-2022, 02:39 PM | #18 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
It was an experience for sure. I've deliberately thrown the rear end out on various occasions when no other cars were around. Sometimes with nannies off and sometimes with them on. In all cases I was exploring the handling and what it felt like at the edge. This one seemed different, but I could be wrong. I don't think anything is wrong with the car that's for sure, although I did take care of that pressure issue. |
07-16-2022, 05:51 PM | #19 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
I keep my non run flat psi around 30 psi. Never had any issues with lowly v6 on dry road.
07-16-2022, 06:36 PM | #20 |
Drives: 21 ZL1 Join Date: Feb 2022
With my ZL1, I get the rear end wagging under WOT. And a lot of idiots think its the rear cradle bushings being too soft and needing to be replaced with hard bushings. They are idiots. If you watch the ELSD in the dash, you can see it moving power between the back wheels to keep you straight and in traction. These cars are very smart and able to keep you pointing down the road even when you shouldnt be. The byproduct can be twitchy handling under WOT. If you watch some of the ZL1 track videos, you can see it even lock the front inside wheel if you are starting to step out in order to straighten you out again.
Any handling quirks are a byproduct of this very smart car keeping your ass on the street and not in a ditch unlike the mustang and hellcat folks. |
07-16-2022, 07:20 PM | #21 | |
Drives: 2020 SS 1LE Join Date: Aug 2020
Back to the OP, your suspension was in the stiffest setting, sport is the sharpest throttle, Bridgestones are less grippy than the stock GY, my guess is you did goose it a bit too much and perhaps that plus surface conditions led to traction loss. No harm no foul. |
07-16-2022, 08:04 PM | #22 | |
Its laughable really to think that people are assuming the rear cradle of the car is moving enough to make the rearend of the car wag under WOT. Funny thing you can stop the wag by putting it in PTM race mode... |
07-17-2022, 07:22 AM | #23 | |
07-17-2022, 07:25 AM | #24 | |
As you said, no harm no foul, and I learned something. |
07-17-2022, 07:58 PM | #25 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
Glad you kept it under control and didn't wreck.
Out on the track, I've noticed that when the back end steps out and it's unanticipated (I didn't think I was doing anything at the time that might provoke it), it seems "different" or perhaps a more violent yaw. That may be the case with you, as in your previous experience, it was you who was purposely making the back end step out (you were ready to catch it), so the actual yaw motion didn't seem so bad or scary. I'd bet your oversteer experience with the pass was caused by too much throttle for the amount of steering angle you had dialed in. The 5 lb air pressure excess in your one rear tire just made this more likely, as would have decreased contact patch, making the rear more prone to lose traction and initiate a spin in the type of maneuver you were attempting. |
07-18-2022, 11:25 AM | #26 |
Drives: 2018 Chevrolet Camaro 2LT Join Date: Mar 2019
My experience with driving on icy roads in the winter with crappy tires is that the stability control will allow the back end to swing out a good 20 degrees before really trying to correct it. It's actually good that it isn't overly aggressive. I bet that while you lost the backend the stability control did it's job and stopped you from completely loosing it.
07-18-2022, 11:36 AM | #27 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Thought from the title this thread would be about someone holding up traffic because of a girl on a bicycle.
07-18-2022, 11:47 AM | #28 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Torque sway maybe. Changing lanes to the left is the direction of torque roll on the engine. Car pulls to the left on hard acceleration. Changing lanes at the same time exaggerates the issue.
Had this issue on my 2016 had to be careful when making quick lane changes while accelerating. Also crowns in the road will definitely throw you around even more so with the wider tires. I-69 is bad for that during their construction around here, throwing my car 3-4 feet at a time side to side in some areas.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
