02-13-2022, 07:05 AM | #1 |
Drives: 2014 2SS/RS MT Join Date: Jun 2021
ZL1 NPP Difference?
I just scored some cutoffs on ebay, now I'm wondering. Is there a difference between the SS and ZL1 versions? I have heard ZL might have larger or different angled tips. Anyone know? Also, should I order the 22829478 diffuser or the 22829477 diffuser for my SS? Appreciate a quick answer before these ship!
02-13-2022, 09:01 AM | #2 |
Tri-County Camaro SWFL
Nothing. Only different NPP setup is the Z/28. SS and ZL1 setup are 2.5in piping. Z/28 is 2.75.
Difference in exhaust comes from the headers, ZL1s have steel headers where LS3s have cast iron and Z/28 are a try-y design.
02-24-2022, 03:53 AM | #3 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
I need to get my hands on a Z/28 system because I’m wondering if when the pipe meets the muffler it doesn’t just neck down making the mufflers the same but the pipe leading to it a little bigger. Idk though Z/28 systems are hard to come by. Zl1 and SS systems are pretty common.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
02-24-2022, 06:34 PM | #4 |
I tend to believe its the same size all the way. Dont know from experience but just my theory from people with vettes doing the "npp mod"
02-25-2022, 04:11 PM | #5 | |
Drives: '14 1LE Join Date: Nov 2013
There's an adapter kit from GM https://www.hawksmotorsports.com/201...ook-up-kit-gm/ |
02-25-2022, 05:20 PM | #6 |
So a Z/28 does NOT have 2.75” mufflers?
02-27-2022, 04:41 AM | #7 | |
Or in our case 2.75”
