04-28-2021, 10:18 AM | #1 |
Drives: '14 1LE Join Date: Nov 2013
Spindle air duct adapters for brake cooling
I've seen a couple of forum users mention these, but haven't found details on customizing these for a reliable 5th gen brake cooling setup suitable for track use. I'm looking for a good alternative to the Quantum kit.
Anyone? https://www.summitracing.com/parts/aaf-all42116 |
04-28-2021, 10:29 AM | #2 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Ive been thinking about trying to 3d print a replacement for the metallic cover that has a spot for a hose. Another probably easier option would be to have a hole cut on the gm part and weld a adapter for ducting into it.
04-28-2021, 11:36 AM | #3 | |
Interesting ideas - please keep us updated! |
04-28-2021, 01:32 PM | #4 |
You could find a set of Z28 ducts and Gen6 deflectors there’s article out there that say this actually better setup than a hose an spindle adapters.
Orange Krush II
04-28-2021, 02:08 PM | #5 | |
I have both (not yet installed). I would be interested to see that article to understand what is "better" about it. Seems like focusing air flow directly to the rotors would be optimal. I had planned to use an adapter to directly connect the Z/28 duct to a flexible duct hose at the wheel well...if I can find a spindle adapter. I also have a set of 6th gen arms I was considering installing (which would obviously work well with the deflectors), but didn't get that far and am on the fence about using it due to the impact on alignment. |
04-28-2021, 09:42 PM | #6 |
There is other articles out there but I can’t find the one I’m looking for but this is a good start.
https://www.essexparts.com/news-blog...n-my-track-car https://vorshlag-store.com/products/...-deflector-kit
Orange Krush II
