08-01-2017, 10:01 AM | #57 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
My 1SS only has the NPP option and NLS does not appear to work on it.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
08-01-2017, 10:48 AM | #58 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I test drove a 1ss non-1LE and a 2ss car, both had NLS as I tested it out on both of them.
If you feel like the NLS isn't working then take the car to the dealer. That should be pretty clear, there could be a sensor not working or a code tripped keeping the car from allowing NLS to work. The 1ss I drove was a base model, only had the regular exhaust and it did it. |
08-01-2017, 11:01 AM | #59 | |
GM does not advertise the feature. I don't think a dealer would work on troubleshooting this. I would like to see video proof of the no lift shift feature in action on a non-1LE SS car. The test would be 100% pedal acceleration in 1st gear, clutch in, shift to 2nd, don't let clutch out and confirm that the engine speed does not hit 6500rpm while at 100% pedal the whole time. I'm not questioning whether or not someone can execute a "no lift" powershift. I'm questioning if there's specific algorithm in action on the non-1LE SS cars which holds engine speed at or less than where the clutch was pushed in since mine and several others apparently do not have it and do not have any fault codes.
08-01-2017, 12:48 PM | #60 | |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
08-01-2017, 01:51 PM | #61 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
Sweet...I've been banging away on my tranny thinking it has NLS this whole time. That's what I get for listening to forum members and not Chevy
08-01-2017, 02:04 PM | #62 | |
@SS_1LE
Drives: 2017 SS 1LE Join Date: Mar 2017
Maybe the NLS parameters were changed when your car was tuned.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S |
08-01-2017, 02:07 PM | #63 |
yup, was stock when I tried.
08-01-2017, 09:36 PM | #64 | |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
No Lift Shift?...This is how its done....
08-02-2017, 12:47 AM | #65 |
Drives: 2016 2ss Join Date: Aug 2016
For the record you may have it. At this point it seems completely random lol. Best test is to go out bring her up to ~6000rpm's clutch in with your foot planted on the throttle, at this point just see how it responds with both the clutch and throttle completely pressed without completing the shift, if it doesnt result in rpms dropping its not active.
08-02-2017, 07:13 AM | #66 |
08-02-2017, 07:16 AM | #67 |
With the calibrations being certified with the agencies, there's no way this is random. It could be a running change (intended or not) that only affected some calibrations though.
I would like to hear straight from Al O. and team an explanation on this one, especially if I'm doing something wrong. At Camaro Fest 7 I got mixed answers on whether or not the SS had no lift shift. Half the employees said yes, the other half said no. Al O. said it has NLS, so I came out of there thinking my car had it, but when I tested it out a few times, it's clear my car does not have it (or I'm doing something wrong and not meeting ALL the enable conditions for it to work). What's the best way to get a response from the Camaro engineers on this?
08-02-2017, 07:26 AM | #68 |
C'mon- really?
Drives: Looking for a ZL1 Join Date: Aug 2009
Awesome vid and that is definitely power/no lift shifting. Thanks for sharing.
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD |
08-02-2017, 06:19 PM | #69 | |
08-02-2017, 08:30 PM | #70 |
