05-22-2011, 06:26 PM | #1 |
Drives: 2010 SS/RS M6 Inferno Orangle Join Date: May 2011
Huge Weight Reduction!
The stock battery in the Camaro weighs in at 44lbs; I replaced mine with a Braille "No Weight" battery (this one: http://www.braillebattery.com/index....tteries/b2317r ). When I received it I thought, WTF, those cats sent me a motorcycle battery! But no, it's a car battery and weighs just under 17 lbs! So I dropped 27lbs just by swapping out the battery.
I also bought one of their aluminum mounting kits and installed the battery on Friday, the car has started and run just fine all weekend. So far so good! |
05-22-2011, 06:39 PM | #2 |
Drives: 2010 Black Camaro 2SS/RS Join Date: Aug 2009
Subscribed. Nice one, Irreverent. I think Doc went this route as well.
My boyfriend don't mind it. |
05-22-2011, 06:40 PM | #3 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
$175, Holy Moly! That is cool though.
05-22-2011, 06:41 PM | #4 |
Drives: cars Join Date: May 2011
Nice weight drop but its only 475CCA. Rather low for anyone in a colder area than FL on a big V8. Heck my corolla has a 600CCA and its a 1.8L.
05-22-2011, 08:11 PM | #5 |
Pictures? I'm wanting to go this route and I want to see how the aluminum mount came out. Thanks!!
05-22-2011, 09:07 PM | #6 |
05-22-2011, 09:08 PM | #7 |
05-22-2011, 09:09 PM | #8 |
05-22-2011, 09:09 PM | #9 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
I got the 21lb one. No probs. 25lb weight savings.
Padre |
05-22-2011, 11:06 PM | #10 |
Mark Stanford
Drives: Black 2010 SS LS3 Join Date: Aug 2010
I put the 15lb version in my ss and ran it as a daily driver for 6 weeks in Chicago 40-50 degree "spring" weather. Too lazy to take it out after April 2nd drag racing at Byron il. Had a slow start last week and put the 44lb-er back in ;-). I think from here on out, I'll take it to the track and switch it out there, or at least haul the 44 with me for quick change in, if I get stranded.
Mark Stanford
2010 M6 Midwestracing on FB CAI, Kooks 1 7/8" 3", LG G6X3, Remote tune by Ted Jannetty JRE God of Tuning, ID 8500 injectors, ZL1 Fuel system, BMR, Yellaterra, Lunati Valve train, Street Slayer Carbon Twin. Numbers pending Dyno test. |
05-23-2011, 01:06 AM | #11 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Yeah, these aren't meant for daily drivers. They work great at the track but i'd be hesitant to trust one, day in and day out.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
05-23-2011, 02:14 PM | #12 | |
Of course, I admit that they ARE trying to sell me a battery.
05-23-2011, 02:55 PM | #13 |
There's a company making lithium batteries for motorcycles now too. They cost $200-220 but have the same CCA as stock. They have similar weight savings as these too. I think 28lbs reduced to around 7lbs. I might make the jump on one of the bikes first since it can already meet power requirements. I'd prefer the price to come down a bit first which it will in time.
Even though my car is a sunny day cruiser I can't reduce the amps that much. I figure in another couple years the batteries will be closer to where they need to be from both a cost and power standpoint and then I'll make the jump. |
05-23-2011, 07:29 PM | #14 | |
Search Ninja
I'm sure they would last a year, maybe two, but these batteries are small for a reason. The manufacturer will say pretty much anything to get you to buy one but know that they had to give up something to make them weigh so much less. That usually translates into less cold cranking amps, less capacity, less residual, etc. I'm no battery expert by any means but to use one of these on a car that you ABSOLUTELY depend on to start and stay running, doesn't seem like a good idea.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
New Brembo Brake Upgrade for 2010+ Chevrolet Camaro SS | CarNutzCustomz | Wheels and Tires Talk Sponsored by The Tire Rack | 42 | 12-22-2011 04:58 PM |
weight reduction options | 2K05GT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 24 | 12-18-2010 08:05 AM |
weight loss | CamaroSpike23 | Off-topic Discussions | 8 | 09-17-2009 07:16 PM |
Camaro Weight | JeepinMatt | 5th Gen Camaro SS LS LT General Discussions | 62 | 03-26-2008 09:17 AM |
