Old 05-16-2014, 07:56 PM   #1
firedrop
Drives: 2012 2ss/l99 a6, victory red
lots of water in exhaust?
so it rained pretty hard today.. after it was over, i started my car up and my exhaust shot at least a gallon of water out. is this a problem? do all exhausts rust?
2012 2ss l99/a6
CAI, custom catback with flowmaster series 10s
firedrop is offline   Reply With Quote
Old 05-16-2014, 08:16 PM   #2
Brandonmos
Brandonmos's Avatar
Drives: 2013 1SS 1LE
A gallon of water? That sounds F'ed up dude
Killed so many water bottles that day...
Brandonmos is offline   Reply With Quote
Old 05-16-2014, 08:24 PM   #3
firedrop
yeah it all shot right out as soon as i started her up though..
2012 2ss l99/a6
Old 05-16-2014, 09:42 PM   #4
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
i doubt you had a gallon of water shoot out the tail pipes. Its not uncommon for it to spray someout but not a gallon worth.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 05-16-2014, 10:22 PM   #5
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
A gallon? Was your car facing downhill while it was raining, allowing the rain to actually fall into your pipes? A gallon is a hell of a lot of water.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 05-17-2014, 05:45 AM   #6
jd10013
Drives: 2012 camaro
everything metal will rust eventually.
jd10013 is offline   Reply With Quote
Old 05-17-2014, 06:23 AM   #7
LBreezie
LBreezie's Avatar
Drives: 2012 Camaro 45th anniversary
don't worry about it, It all evaporates or just gets blown out the back when you drive it.
LBreezie is offline   Reply With Quote
Old 05-17-2014, 08:28 AM   #8
ChrisBlair
Buick 455 Fan
A lot of people have a hard time estimating volume and distance.
Unless it smelled like coolant, it wasn't a gallon. Ever see dew on grass in the AM?
It is normal, especially when humidity changes, to get water condensed in the exhaust. This happened after a rain storm.
My car with the big tube headers will cough up about a pint from each pipe as SOP, when started up in the morning. Water condensing in the exhaust overnight as the temp drops.
Old 05-17-2014, 10:10 AM   #9
SuperSport2011
SuperSport2011's Avatar
Drives: 2011 camaro 2ss/rs rally yellow L99
Do you have a stock exhaust? Cus I swear there are small holes at the bottom of the mufflers(about a 1/16 of an inch) to allow water to drain if it builds up. I can't imagine a whole lot of water building up.
- Airaid cold air intake - Kooks 1 7/8 long tube headers
- Kooks high flow cats - Borla atak 2.5" cat back exhaust - Dyno tune - AFM delete - 94 octane tune - Vitesse paddle shifters - Blacked out rims - Costum painted engine cover - T3 stripes - GM locking gas cap
SuperSport2011 is offline   Reply With Quote
Old 05-17-2014, 10:47 AM   #10
Brandonmos
Brandonmos's Avatar
Def condensation that built up on the cooling metal over night like said above
Old 05-17-2014, 11:40 AM   #11
ChrisBlair
Buick 455 Fan
Originally Posted by Comrando View Post
Spark it up and blow it out
Please! We call that "the Italian tuneup"
