Old 02-20-2014, 05:09 PM   #1
Blk_SS
Drives: black on black 2SS/RS
600-700hps guys input please
I have a twin turbo ls3 and im about to add meth to the car, my question is if i want to crank up the boost should I go ahead and upgrade my head stud and head gasket?
Blk_SS is offline   Reply With Quote
Old 02-20-2014, 05:17 PM   #2
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I would, better to overcompensate than come up short.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 02-20-2014, 05:18 PM   #3
ddck24
ddck24's Avatar
Drives: 2012 Camaro 2ss 45th M6
Yes arp studs and some good head gaskets...
I had stock ls3 gaskets on my old build and they were about blown when we put new gaskets on the other night
ddck24 is offline   Reply With Quote
Old 02-20-2014, 05:29 PM   #4
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Crank up the boost to what
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 02-20-2014, 05:39 PM   #5
prdi
Drives: CTS-V
yes whats your setup consits of? you go do that i would just change the cam and keep the boost where its at and be making more power
prdi is offline   Reply With Quote
Old 02-20-2014, 05:40 PM   #6
Unreal
Drives: 2006 Z06
600-700rwhp no point in touching the motor. If you are pulling the heads then do it to upgrade the heads/cam, not just swap gaskets/studs.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 02-20-2014, 06:32 PM   #7
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Agreed, lots of 600-700rwhp untouch LS3 long blocks out there.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 02-20-2014, 06:47 PM   #8
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
Made 11PSI and 680RWHP for years on a stock LS3.
Inferno LSX is offline   Reply With Quote
Old 02-20-2014, 08:21 PM   #9
Blk_SS
As Of Right Now My Mod Are Turbo Kit And Cam On 7 Psi Of Boost, I'm Adding Meth Soon And Cranking The Boost Up I Want To Be In The 700Rwhp range
Old 02-20-2014, 08:38 PM   #10
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Agree
Frans96ss is offline   Reply With Quote
Old 02-20-2014, 09:12 PM   #11
Levischilz
Drives: 2012 Camaro SS Transformers Edition
well 8 psi and meth should be there.
I at like 8.5 and almost 700 rwhp no cam and no meth
Raise boost 1-2 psi and meth and your good.
Levischilz is offline   Reply With Quote
Old 02-25-2014, 03:58 PM   #12
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/ ctsv3
I would do a head gasket and studs, I was at 620 wheel and my head gasket blew at the water jacket and put a hole in the #7 piston and scratched the hell out of the sleeve..
A lot are over that un touched but if your luck sucks like mine does then save urself now
2012InfernoSS is offline   Reply With Quote
Old 02-25-2014, 06:22 PM   #13
old motorhead
Drives: Maggie blown LS3 vette
Or...if your tune, octane, or fuel supply is inadequate, you need all kinds of help. If the previous mentioned items are adequate, you don't need to worry at mid 600's.
If you have a crappy tune, crappy octane, or poor fuel supply....the greatest head gasket and studs won't help.
old motorhead is offline   Reply With Quote
Old 02-25-2014, 06:28 PM   #14
2012InfernoSS
It is what it is..
Just telling him don't cry if something happens.. every engine is different
Sent from my SM-N900A using Tapatalk
