TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 03-25-2014, 04:34 PM   #1
Silver_Flake
Silver_Flake's Avatar
Drives: 2013 IOM SS
Service Stabilitrak & Service Power Steering
Okay fellas, I need your expertise! Last week I installed my Kooks LTH and mid-pipes. I had a buddy help me because I knew id need an extra pair of hands. Well, long story short, when I was unbolting the steering shaft to make room for the headers to fit, my friend decided it was a good idea to let go of the steering wheel I know it spun a couple times. Well, after start-up, I get a "Service Stabilitrak" whenever I move my steering wheel at all. ALSO, I get a "Service Power Steering" When I turn my steering wheel too far to the right.
So, my question is, what parts will I need to fix this? After searching some threads, I have kind of narrowed it down to a steering angle sensor and/or a clock spring. I noticed a lot of people replaced the sensor for their "Service Stabilitrak" problem, but I haven't seen anyone with a "Service Power Steering" problem which makes me think I may need to replace my clock spring as well
Will I need both parts to fix this problem? Help me out guys. I appreciate it. Thank you!
Silver_Flake is offline   Reply With Quote
Old 03-28-2014, 12:55 AM   #2
Silver_Flake
Drives: 2013 IOM SS
Bump
Old 03-28-2014, 04:52 AM   #3
332
Drives: 2SS
I believe that the steering angle sensor is of...and it needs recalibration,the dealer will help you here...
332 is offline   Reply With Quote
Old 03-28-2014, 06:33 AM   #4
serows1
serows1's Avatar
Drives: Blue Ray 2SS
First, get a new friend...
Second, sounds like you spun the SIR coil behind the steering wheel, you'll need to replace it.
Good Luck,
Paul
serows1 is offline   Reply With Quote
Old 04-05-2014, 11:01 AM   #5
Silver_Flake
Drives: 2013 IOM SS
Thought I would bump this one more time before I take it to the dealership.
Do you think I just need them to center/recalibrate the wheel with the angle sensor?
Old 10-14-2014, 05:42 AM   #6
dkbmx993
Drives: 2010 camaro ss 6spdmanual
How did you fix this? I have the same problem
dkbmx993 is offline   Reply With Quote
Old 04-12-2020, 04:32 PM   #7
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
What was the fix for this? Lost power steering and every light possible was on, including brake light while i was driving through neighborhood..
Hellfighter is offline   Reply With Quote
