06-17-2015, 11:41 AM | #29 |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
It does have a more efficient transmission with 8 gears though. Perhaps the HP to the ground will be about the same, with less torque...more gears helps that less torque.
I do agree, it won't be as fast on average. But it will be pretty close. |
06-17-2015, 11:58 AM | #30 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
You don't believe it...fine, but this thread is based on what was stated by a high ranking GM exec, so that's what we are going to discuss here. Anyways... Something to think about. The 2009 Nissan 370Z (330HP/270TQ) runs a 13.3 in MT testing with a 6 speed manual, weighing 3,355 pounds. Now, I don't know what the final drive ratio is on that car, but I believe it is numerically higher than the Camaro manual will have. So...add 100 pounds and a more mpg friendly final drive ratio....should equate to 13.5 to 13.7 easy. The same 2009 Nissan, but with the seven speed automatic weighs 3,368. Ran a 13.1 at 108mph in Car and Driver testing. Again, likely has slightly numerically higher gearing and weighs roughly 100 pounds less. Should equate to around a 13.3 to 13.5 quarter mile for the Camaro....all else being the same. The 370z has high some high 12 second hero runs on street tires. As for comparing to the 4th gen. I still give the 4th gen SS (especially manual) the advantage, but it shouldn't be nearly as great of an advantage as the 5th gen V6. EDIT: 370z 7speed auto has a 3.357 ratio, whereas the new 8 speed V6 will be 2.77. That's a sizeable difference but with the extra gear lessening the ratios between the first 4 gears, I can't imagine it would add more than 1 or 2 seconds to the 1/4...all else being the same. The turbo 4 8 speed will have a 3.23.....maybe a swap to the V6 will be in order lol.
2010 Camaro 1LT V6 (Sold. I will miss her!) Last edited by KMPrenger; 06-17-2015 at 12:52 PM. |
06-17-2015, 02:33 PM | #31 | |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
This is the 370Z's effective gearing and it isn't even factoring in the tire height difference which would make it even better vs the 6th gen V6. 1st-16.52 2nd-10.72 3rd-6.85 4th-4.74 Like I said earlier. If the weight holds up I think we will see low 13's hero times. Mag times will probably be in the mid-high 13's but noticeably quicker than the Ecoboost.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
06-17-2015, 05:53 PM | #32 | |
Drives: 2012 Camaro 2SS Join Date: Feb 2012
06-17-2015, 06:54 PM | #33 |
OK buddy...if you say so.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
06-17-2015, 09:31 PM | #34 |
Drives: Chevy Join Date: Mar 2015
06-17-2015, 09:38 PM | #35 |
Drives: 2017 1SS 1LE Join Date: Sep 2014
Fixed that for you...
06-18-2015, 06:50 AM | #36 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
The heaviest Cadillac ATS (non V) has AWD and comes in at 3,461 lbs. I believe. I'm not sure why people would question the LT Camaro coming in at around that if Al O. says the weight loss is near 300 lbs. over the Gen 5. After all, that's two data points suggesting 3,4xx as the weight.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
06-18-2015, 07:29 AM | #37 | |
Drives: 2016 F150 Join Date: May 2014
06-18-2015, 08:11 AM | #38 |
06-18-2015, 08:59 AM | #39 |
Sorry, typo. 3,561 lbs.
06-18-2015, 10:11 AM | #40 |
06-18-2015, 10:12 AM | #41 |
Drives: camaro Join Date: May 2013
Along with the ugliness of the 4th gen
Hyperblue/JetBlack |
06-18-2015, 10:15 AM | #42 |
That's my point. AWD (as well as extra sound deadening and luxury items) adds weight. So if you take 3,571 and take away 160 lbs you get 3,411 lbs. How is it hard to believe the 6th Gen LT will be in the 3,4xx range?
