Old 02-22-2024, 04:39 PM   #1
robka
Drives: Chevrolet Camaro
P0106 and other DTCs
Hi,
first please excuse my English - I'm from Germany.
I’ve got a 2018 Camaro SS.
LT4 Supercharger conversion
BTR Stage1 blower cam
Breakout harness from maf to map
Tuned
Current setup since nearly 1 year
At first with a CAI and now with the stock airbox since 4-5 month.
Only table changed from CAI to stock airbox was MAF.
Since about a month following happens:
On every drive there's trouble code P0106 when I read it with my MPVI3
I only began checking this, because sometimes it's throwing a CEL, because of that.
CEL isn't always on and can be deleted. The fault code stays and can't be deleted.
Sometimes there's also U0401-71. I don't know if this triggers the CEL or of it's triggered through continuous P0106.
https://imgur.com/H1x5jvD
On top of that more less the oil pressure also shows zero but pressure is there. See also attached picture. Note: metric scale
https://imgur.com/UtiI8DD
When oil pressure is showing zero my mpvi3 with TDN app isn’t working anymore. So I’m not able to log or read dtc.
I already sprayed the whole motor and intake with brake cleaner to locate any vacuum leak but nothing found.
Today I disconnected the breakout harness and did a continuity test to it with a multimeter. All ok.
I couldn't test it for 5v or grounding, because I didn't have the little test probe pins for the plugs at the moment.
Ignition was off the whole time.
After a start it threw me various errors and a CEL. See attached screenshot.
I was able to delete all of them but P0106.
https://imgur.com/cwIAuPy
https://imgur.com/RQljn9l
Could the map sensor be the problem and cause also a shown zero oil pressure and no working mpvi?
Or do anybody have an idea?
robka is offline   Reply With Quote
Old 03-05-2024, 06:04 AM   #2
robka
Nobody?
Old 03-05-2024, 06:39 AM   #3
ctrlz
You could try reposting this in either the tuning or forced induction sub-forum.
You have a lot of modifications.
