Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 06-08-2021, 11:06 PM   #1
67-LS1
67-LS1's Avatar
Drives: 1966 Chevelle
Intermittent starting issue
Sometimes when I try to start my car I just get a clicking. Just like a dead battery. But if I turn the key over and over, eventually it will catch and start. Spins like crazy.
I’ve checked the battery cables, grounds, etc but still the same thing.
Any ideas?
66 Chevelle with 2013 LFX V6, 6 speed auto, full Hotchkis suspension, Wilwood 4 wheel discs.
67-LS1 is offline   Reply With Quote
Old 06-09-2021, 01:20 AM   #2
AlanRubin
Drives: 2010 LS
More then likely, it's the starter, signs of it starting to go bad, usually the solenoid,
which is built into the starter.
AlanRubin is offline   Reply With Quote
Old 06-11-2021, 06:14 PM   #3
67-LS1
67-LS1's Avatar
Crap. Well I guess I’ll change the starter. Maybe the parts store can check it first.
Old 06-12-2021, 10:13 PM   #4
xstuntman
Drives: 2012 Victory Red LFX
Could be a bad relay or solenoid, loose wiring or low voltage. Even a weak FOB battery could cause it.
If the above check out adding extra grounds to the alternator starter and ECU might help. These cars have a rediculous amount of grounding going on.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
xstuntman is offline   Reply With Quote
Old 06-13-2021, 12:29 AM   #5
67-LS1
67-LS1's Avatar
Thanks. I hope to get my brothers 65 Mustang off my lift tomorrow and check this out. Hopefully it’s something easy like a loose wire.
PI’ve got ground straps on three corners of the block, two to the body and one to the frame. and the forth corner is the ground cable to the battery.
Old 07-02-2021, 03:25 AM   #6
AlanRubin
Drives: 2010 LS
A weak FOB battery has nothing to do with the starter, and won't cause anything
but the doors not to unlock or lock. The starter grounds through the metal housing
where it bolts to the car. Adding grounds will do nothing for the starter. Where
do you people come up with this crap? Weak FOB battery? Come on!!! Only if
it has REMOTE START, and the car didn't get the signal because of the weak
battery... This guy said nothing about remote start, and said he checked all the
grounds, which there are TWO MAIN grounds.
The starter has TWO connections, and TWO BOLTS, and that's it. I just did mine,
and it was easy. These cars are known for starter issues.
When it SPINS like crazy, that means the starting gear was not thrown out to catch
the teeth on the flywheel.
Also, you do not even need to HOLD the key in the start position to crank the
engine. All you do, is turn to start and release, and the electronics to the rest. It
will crank on it's own, and stop when the car starts, or stop after 5-6 seconds if there
is a no-start. If the starter motor is stuck, it clicks ONCE, then after 5-6 seconds it
clicks again when the solenoid is released.
The starter has the solenoid ON the unit, so all you have is a relay that sends power
to the solenoid. TWO wires, that one, and battery power from the jumper post. The
starter is always 12V Hot, and engages when the solenoid is latched.
The FOB doesn't even NEED a battery to start the car. The transponder is powered
INDUCTIVELY at the ignition cylinder. You have no idea how the system works, and
you don't have any right to offer help when everything you wrote was incorrect!
If the car doesn't read the key, the LOCK light comes on, and you won't even
GET a click. If you don't know how the system works, you should READ, and
KEEP reading.
Old 07-02-2021, 08:23 AM   #7
67-LS1
67-LS1's Avatar
I ended up replacing the starter. I could not imagine what else it could have been.
This engine is not in a Camaro. It’s from a 2013 Camaro but it’s in my 66 Chevelle, so I don’t have a key FOB or remote starting. I have an old style key that you do have to keep turned to keep cranking.
When I said spin like crazy I meant the engine would spin and start so it wasn’t the bendix. When it didn’t start it sounded exactly like the click of a dead battery.
Anyway, thanks for the inputs but (fingers crossed) it’s now working.
I did notice on the new starter that there is a flat pad on the top thats painted green like for a ground screw. The old one had the same pad but no green paint. There had never been a screw in it so it was never grounded in the Camaro donor car either. It might have been for another application???
And it was a bitch to get the starter out because of my motor mounts. I clearly did not leave enough room between the starter and the mounts I built to get the starter out. My bad.
Old 07-02-2021, 11:33 AM   #8
xstuntman
Alan,
Its typical of many cars to not start with a dead or weak FOB battery. Also adding grounds is a common practice and has been used often here on Camaro5. We are hear to help each other but you just come off as angry.
Forget the Metamucil maybe?
Have a great day BTW.
Old 07-03-2021, 07:34 PM   #9
67-LS1
67-LS1's Avatar
Well, It wasn’t the starter… We went for a drive to the coast today and stopped at 8-10 different places and three times it just clicked. I kept trying and it eventually starts.
My wife thought the clicking was from the key area, not under the car, so I’m going to change out the ignition switch just to be sure. Cheap insurance and I’ve never changed it before so it could very well be original 55 year old switch.
If that doesn’t cure it I’m at a loss.
Old 07-06-2021, 06:40 PM   #10
Pagliaro
RIP Betsy ( Vitara )
Pagliaro's Avatar
Drives: '11 SGM 1LT/RS
Send a message via AIM to Pagliaro Send a message via MSN to Pagliaro Send a message via Yahoo to Pagliaro
This happened to me in my camaro and it was the starter. Odd it wasn't for you.
First retrofitted 2014 mylink.
Pagliaro is offline   Reply With Quote
Old 07-07-2021, 10:34 AM   #11
67-LS1
67-LS1's Avatar
I now think it’s my neutral safety switch.
I had to cut my own shifter detent plate to make the stock Chevelle shifter work with the 6L50 transmission. The NSS was replaced when I put it in (because I broke the old one) so I’m checking the throw to make sure it’s aligned.
There is some adjustment in the switch. But I have to pull my custom console which requires pulling the passenger seat and the back seat bottom so a minor PITA.
Old 07-09-2021, 06:03 PM   #12
67-LS1
67-LS1's Avatar
That was it! Neutral safety switch. The linkage is not as tight as it should be and was pushing slightly sideways on the switch.
I’m going to look at reconfiguring then whole mess.
Thanks for all the suggestions.
