dave@hennessey
Old 01-05-2021, 07:31 PM   #1
Bubbafire88
Bubbafire88's Avatar
Drives: 2010 Camaro ss A6 "Chief"
Smile What should i buy
HI, i just bought a new-to-me 2012 camaro ss a6 with 92,000 miles on it, i have 1600$ to spend on modifications for it, what would yall recommend for a bone stock l99 to get some power with a lot of sound?
Bubbafire88 is offline   Reply With Quote
Old 01-05-2021, 08:18 PM   #2
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Long tube headers and a tune, whatever you do, don't do a muffler delete. It sounds like a weak tractor and when the AFM kicks in, its going to sound like a bathroom sound. Happy modding.
Heres what the headers, CAI and muffler delete sounds like. Its pretty gross, real anemic sounding.
But if you cam it and run open headers should be more like this (first time at the local badly prepped 1/8th, not a good night..)
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 01-05-2021, 09:43 PM   #3
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Agree, headers first
joshnmn is offline   Reply With Quote
Old 01-05-2021, 10:05 PM   #4
BuddyLee
BuddyLee's Avatar
Drives: 2013 Camaro 2SS/RS
What other parts are needed with the long tube headers for the mod?
BuddyLee is offline   Reply With Quote
Old 01-05-2021, 10:31 PM   #5
Roader
Drives: Camaro
Chris is spot on. I’d add a ported tb too
Roader is offline   Reply With Quote
Old 01-06-2021, 04:20 AM   #6
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Headers: https://www.speed-engineering.com/sh...stainless.html
https://www.texas-speed.com/p-5465-t...ess-steel.aspx
Tune: many options, hit up dynosteve or many of the other reputable choices.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 01-06-2021, 06:35 AM   #7
Lou gill
Lou gill's Avatar
Drives: ‘13 ZL1 convertible
A tune from RDP
Lou gill is offline   Reply With Quote
Old 01-06-2021, 08:12 AM   #8
saluki
Drives: 2017 Silverado
2" Texas Speed Headers
Cold Air Inductions Cold Air Intake
A Tune from Steve at RDP
Do the work yourself and this can be done for $1600
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 01-06-2021, 08:40 AM   #9
Chris49066SS
Drives: 2010 SS L99
Honestly, for the headers, at least if you stay with a 1 7/8 you don't have to worry about any contact with the frame, so the headers can be done by yourself in an hour or 2, and don't need any other mod to function and make you loud, they will still work without a tune, but they will not give you the same power increase they otherwise could with a proper tune, and they will throw a check engine light. And you'll likely foul out your O2 sensors pretty quick.
But the other dudes said it well, those are all good mods to throw on that will help it breathe and give you crisp throttle response. The butt dyno will be happy until the itch for more mods comes along...and it does..
Old 01-06-2021, 11:16 AM   #10
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
I would hold off until we see what the new administration /green deal will bring .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 01-06-2021, 11:53 AM   #11
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
rear gears are a better bang for the buck on an auto. Just my .02.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 01-06-2021, 06:04 PM   #12
Bubbafire88
Thank you all for the information, this has helped me alot with deciding what i should get. ive seen the speed engineering 1 7/8 long tube headers for the 5th gen camaro, and they are only about 300$, do yall have any experience with these headers?
Old 01-06-2021, 06:39 PM   #13
Warship2k15
Do a search many people have them and are happy with them.
If I decide to go that route I will probably have mine ceramic coated to keep down on the engine bay heat.
Warship2k15 is offline   Reply With Quote
Old 01-08-2021, 03:05 PM   #14
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Headers and tune will improve performance. Muffler delete will make it loud if that is what you mean by a lot of sound. Don't do the muffler delete without headers or it will sound like you need a muffler, not like the car is quick.
I have Speed Engineering headers on my truck. They are good for the price.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
#camaro, #help, #mods
