11-10-2017, 01:09 PM | #1 |
Drives: Camaro 2SS 2013 Join Date: Sep 2014
For Cam Experts
Hello..
How this cam specs sound like. How will be the tourqe out of this cam. It is VVT 215-235 121.5 +8
Camaro 2013 2SS/RS L99 VICTORY RED
VMAX PORTED THROTTLE BODY, ROTO-FAB CAI, FLOWMASTER OUTLAW AXLE-BACK WITH J-PIPES. VITESSE THROTTLE CONTROLLER. 1LE 3.91 GEARS. KOOKS 1 7/8 LTs, CAT DELETE, GPI SS2 VVT CAM, ATI 10% UDP, MELLING HIGH VOLUME HIGH PERFORMANCE OIL PUMP |
11-10-2017, 01:31 PM | #2 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Look in to the Texas Speed VVT Cams.
Their VVT 3.2 makes 120hp over a stock L99 at the flywheel. Sent from my iPhone using Tapatalk
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
11-10-2017, 02:00 PM | #3 |
No actually this is for stealthy cam. No lope and stock drivablilty. Good for blower
11-10-2017, 02:35 PM | #4 |
Drives: 2015 Camaro 1SS L99 Join Date: Apr 2016
Ive tried asking Texas Speed but they wont respond. Whats the difference or improvement from a VVT stage 3 cam and the new 3.2s? new tech or different grind or what?
11-10-2017, 04:45 PM | #5 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
http://www.hotrod.com/articles/ls-cam-test-comparison/
Nothing is free. A bigger cam usually doesn't make more torque below 4000rpm. If you want high rpm horsepower then put in a longer duration higher lift cam. The cam you list sounds good if you include good valve springs so you don't break things. You could gain 50 or 70hp at higher rpms. |
11-10-2017, 11:05 PM | #6 | ||
LSx FTW!!!
11-11-2017, 04:09 AM | #7 | |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
http://www.chevyhardcore.com/news/te...ms-add-100-hp/
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
11-11-2017, 07:13 AM | #8 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
Those specs might as well keep the stock cam IMO and call it stealth.....and you did not even mention the lift..LOL
11-11-2017, 11:01 AM | #9 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
11-11-2017, 05:13 PM | #10 |
Lift is around .630
11-12-2017, 08:15 AM | #11 |
This cam has a lot of LSA with added in timing for running...Stealth along with not too much duration and the lift obviously is trying to make up then for the inadequate LSA and duration, you want more power you would have say a 112 LSA no + and a 230 up duration on both for that lift more in the night fury range... Why think about that cam. Are the Nazi engine police really that bad in in Saudi Arabia? I thought you could buy gas there for like 25 cents a gallon......Or are you the dude who has to keep the car mild because dad drives it also?
Frankly just like any engine the more you change things out the more your likely to F something up and scrape bearings pulling the cam out again, IMO I would just stick with the cam you have as your not going to gain much....... The torque to improve is based on varying factors the best way to improve your torque would be a much better cam, stroke the block, or Forced induction. Each would have effects in that order weakest to strongest effects. You would have to look at exactly the same engine with a comparison with just a cam swap with a dyno sheet to show the torque difference from other cams or stock in a comparison. I would think that would be a mild cam, large LSA better for low end torque but your an automatic which is bad for low end torque, why not just get a throttle controller....a larger LSA and the effects of it can be found online through comp cams, the duration of the cam effects opening and closing events and most people would recommend you use more duration rather than lift which is hard on the valve train. http://www.compcams.com/Pages/413/ca...ion-angle.aspx so what you want more power and good drive ability and stealth....you should be looking for the perfect exhaust with some cut outs not playing with the cam repeatedly but going more for power with the cam......
11-12-2017, 11:37 AM | #12 |
Big Crow
11-13-2017, 07:23 AM | #13 | |||||
LSx FTW!!!
It can be bought lower depending on what parts you need. Select options here: https://www.texas-speed.com/p-260-ts...t-package.aspx Probably the best $1,300 you could spend because I don't know of any other bolt-on for that price that adds up to 130.5hp (TSP VVT 4.2). Here are all their VVT cams:
