Vararam
Old 04-15-2017, 06:33 AM   #1
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Need new battery
What's everyone using these days for a replacement battery? OEM/other? Mine is about five years old and seems very weak. Very hard start this morning and got a Christmas tree on the dashboard. Would this be normal to get the Christmas tree dash with a weak battery?
Soprano 4/1/00-6/14/11, Gone but NEVER forgotten!
FSP tuned: 377/389
nyrfan is offline   Reply With Quote
Old 04-15-2017, 07:20 AM   #2
snarky
ultracrepidarianism
snarky's Avatar
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport
meh they are all the same. get the correct size and a fair warranty.
snarky is offline   Reply With Quote
Old 04-15-2017, 07:51 AM   #3
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Agreed. Most common/popular brands will do the job.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 04-15-2017, 07:56 AM   #4
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
I put a Interstate battery in my '10 SS. Vented, perfect fit and great warranty.
myold88 is offline   Reply With Quote
Old 04-15-2017, 08:02 AM   #5
nyrfan
Let's go Rangers!
nyrfan's Avatar
Thanks guys. Does it make sense that I got the Christmas tree dashboard?
FSP tuned: 377/389
Old 04-15-2017, 08:36 AM   #6
Reaper85
Drives: 2013 2SS/RS
I always go agm. Maintenance free completely sealed non venting. But that's personal preference as I always put stereos in my cars, and agm's are the best when it comes to deep cycling and quicker discharging.
Reaper85 is offline   Reply With Quote
Old 04-15-2017, 08:40 AM   #7
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
My original battery is still going strong at almost 8 years old. However I know I am on borrowed time and I just bought a AC Delco 94 AGM to replace it. If you are having a hard time starting your car, that's the first sign of a weakening battery.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 04-15-2017, 10:28 AM   #8
nyrfan
Let's go Rangers!
nyrfan's Avatar
Batteries don't tend to last that long here in the Florida heat.
FSP tuned: 377/389
Old 04-15-2017, 10:37 AM   #9
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Yes, it may be the cause of the "christmas tree" on your dash. I've owned several modern muscle cars, and they all tend to act strangely when the battery voltage gets lower than normal. I've heard and experienced symptoms that you normally wouldn't consider voltage related, turn out to be directly related to voltage drops of only a few tenths (battery resting voltage still showing 12.1-12.3). Many don't realize that is an exponential drop as far as starting power goes, and the modern electronics on these cars do not handle that well. If you're in doubt, take the battery out and have it load tested at a local autoparts store. At the very least, test your resting voltage after the battery has set overnight using a voltmeter. If it's not showing at least 12.5 or better, I would have it load tested.
As far as what battery to choose, I haven't had to change mine out yet, but the OEM seems to generally hold up very well, owners getting 4-7 years out of them fairly regularly. I live in a climate that eats batteries, so I always keep mine on a Battery Tender since it's not a DD.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-15-2017, 10:49 AM   #10
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Drives: 2013 Camaro 2SS/RS & 2006 Corvette
As other's have said, most name brands are about the same. Around here, I get batteries for all my vehicles from AutoZone, with the military discount, they are the cheapest and I've never had a problem.
Welker2 is offline   Reply With Quote
Old 04-15-2017, 11:26 AM   #11
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Delco or NAPA.
Don't fight with the Wa-Mart crap.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 04-15-2017, 01:49 PM   #12
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
After getting a Costco membership, I saw they have interstate batteries fairly priced. That's what I would get. Aside from interstate, I have a duralast gold battery in my Acura. Been almost 3 years no problems.
Lil' Nasty is offline   Reply With Quote
Old 04-15-2017, 01:52 PM   #13
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
I recently bought a AC delco AGM from the dealer a la carte so it had some warranty to it. Few bucks cheaper on Amazon but no warranty there really. I have a sub and amp otherwise I might have tried a braille battery.
Deftones is offline   Reply With Quote
Old 04-15-2017, 10:57 PM   #14
Cyber/Orange10
Cyber/orange10
Cyber/Orange10's Avatar
Drives: 2010 2SS 96 CE LT4, 12 CRUZE ECO
Send a message via AIM to Cyber/Orange10
just replaced my 7 yr old battery before I get trouble with Farm and Fleet 7 yr battery for 99 bucks before tax, as good as any and when not driving it for a week or so use a battery tender keeps them for sulfating and dieing.
Cyber/Orange10 is offline   Reply With Quote
