Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 01-27-2015, 07:54 AM   #1
Jasper
Jasper's Avatar
Drives: 2011 Summit White Camaro SS (LS3)
Guys with 3.91 gears in a 6spd manual
I would like to know a couple of things before I do this:
1) I understand that the powerband will shift. How does it feel when on the highway and you want to downshift to pass? Do we lose a lot of top end power after the gear install in favor of low end power?
2) Has anybody done a 0-60 run? This is the area i'm trying to improve upon rather than the quarter mile. I understand I should be able to get off the line quicker but will lose top end which is fine with me. But I'm wondering if there is a real improvement in 0-30, 0-60 etc.
Any negative feelings with the gears? Is 1st gear still useable? Will I be needing to shift at a really low speed now?
Thanks
J
Jasper is offline   Reply With Quote
Old 01-27-2015, 08:07 AM   #2
H-E
Drives: 2010 zr1 Camaro 2011 vert
What is your power?
H-E is offline   Reply With Quote
Old 01-27-2015, 09:23 AM   #3
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
You don't lose any top-end power (or any power, for that matter). You'll just get through your powerband quicker and you'll feel like you have more torque everywhere. I still think it's the best bang-for-your-buck mod out there.
If you're N/A, first gear will be perfectly useable. If you add a PD blower, it gets a bit dicey, but scary fun (I used to have 4.10s, before I grenaded them).
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 01-27-2015, 10:00 AM   #4
Snidely Whiplash
Fight Crime, Drive Armed
Snidely Whiplash's Avatar
Drives: '14 2SS Yelo Maro, HD collection
Originally Posted by H-E View Post
What is your power?
I guess he no savvy?
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
Snidely Whiplash is offline   Reply With Quote
Old 01-27-2015, 10:00 AM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
This. You will have an equivalent torque gain of approximately 13% or 54.6 lb.-ft. of torque at all RPMs.
Apex Motorsports is offline   Reply With Quote
Old 01-27-2015, 10:57 AM   #6
Jasper
Jasper's Avatar
Sweet. I am normally aspirated with an intake and tune.
But does the zero-60 improve?
Old 01-27-2015, 06:41 PM   #7
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
What size drag radials or slicks?
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 01-27-2015, 07:55 PM   #8
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
0-60 improves if you get traction. Overall I like the 3.91's. On the highway the car feels much lighter and I don't see a reason to downshift. It picks up faster now
camarosspower is offline   Reply With Quote
Old 01-27-2015, 08:37 PM   #9
beasstmode
Drives: 2011 camaro ss
How much does it affect the overall top speed?
beasstmode is offline   Reply With Quote
Old 01-27-2015, 10:51 PM   #10
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
How much will it help in the 1/4m or 1/2m over the stock 3.45's? I'm cam only
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 01-27-2015, 11:17 PM   #11
camarosspower
Helped me on the 1/4 with a .2 faster and two mph gain from my previous run on a worst 60'. That was my first time out there with the gears and I only done two passes that night. Only downfall I can think off is 4th gear ends at 140mph. I didn't shift into 5th as I thought that was fast enough.
Old 01-28-2015, 02:47 AM   #12
LSXBumblebee
LSX Bumblebee
LSXBumblebee's Avatar
Drives: 2014 LSX Camaro
5th can do 155 with plenty of room to go
3.91 is great if you like spinning tires when you have a supercharger. lol
LSXBumblebee is offline   Reply With Quote
Old 01-28-2015, 05:56 AM   #13
camarosspower
Does 5th gear still have any power in it or will it just bog down? Isn't that a cruising gear?
Old 01-28-2015, 11:38 AM   #14
Merc
In The Circle
Merc's Avatar
I have had both 3:91 and 4:10 in my M6 car loved them both. If I had to choose a favorite 4:10 would be the ones I liked best. Turned 11:72 with those gears, Bolt On's with slicks and skinnies.
