08-18-2018, 04:04 PM | #57 |
Drives: 2018 ZL1 M6 Join Date: Dec 2017
08-18-2018, 08:42 PM | #58 |
Drives: '18 Zl1. '18 GT350. Join Date: Dec 2016
So, I'm assuming this won't work with a Pro Charger set up then right?
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
08-24-2018, 07:55 PM | #59 |
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC Join Date: Mar 2016
We're planning to open up the group buy at 20% off for the first 10 kits! I think this will start 9/4 at the moment.
That was a Procharger in the pic up there, but you have to get rid of the air to air intercooler and go air to water. I still need to find time to write that up, but on the C7 air to air cooler, we were spinning the blower nearly 76K RPMs making 21 PSI into the LT 427 and there was a 8 PSI pressure drop through the intercooler, meaning the . We slowed the blower down to 70K blower RPMs, making 25 PSI and nearly 200 WHP more! Last edited by WEAPON-X; 09-01-2018 at 08:18 PM. |
08-24-2018, 07:56 PM | #60 |
08-24-2018, 08:04 PM | #61 |
Drives: 2017 ZL1 A10 Join Date: Jul 2014
Its the intake manifold temps.
08-24-2018, 08:08 PM | #62 |
I'd need to see the results on a stock LT4 ZL1 blower before I'd be interested first. Is that in the works?
08-24-2018, 10:34 PM | #63 |
Drives: 2017 ZL1 Join Date: Jan 2017
Two different points on the intake manifold that should be measured at the same point for temperature comparison
I would have forced the scale on it (not sure if your device is capable) so the color scale based on min/max temp is equivalent, would make a more stunning photo
08-24-2018, 10:43 PM | #64 | ||
https://www.camaro6.com/forums/showthread.php?t=536113 Quote:
Those pictures were taken seconds apart of a Whipple supercharger and I'm showing you how much cooler the coolant crossover tube on the front of the unit is than the rest of the entire unit. This was after back to back pulls and the crossover tube is aluminum and obviously picking up heat from conduction and convection and it is STILL 46* colder than the rest of the supercharger! Think about how cold the fluid would need to be inside of this in order to combat supercharger temps and the Whipple got even hotter afterwards as the internal heat bled through the housing, but the cross over tube just kept getting colder. |
08-24-2018, 10:44 PM | #65 |
I understand but the engineer in me says "you done wrong"
08-24-2018, 11:15 PM | #66 |
08-25-2018, 12:00 AM | #67 |
Drives: Grandad's C2 L89 Join Date: May 2017
2018 ZL1 1LE sw/PDR
08-26-2018, 10:30 AM | #68 |
Drives: 17 black 6m < 18 garnett a10 Join Date: Sep 2017
Being a hvac technician here in arizona, I'm curious to see cabin temps between a stock car and one with a chiller here in arizona when we have a 120 degree ambient. The idea is great if you live in the midwest. Maybe heat up the dyno room and post some data between the two.
08-26-2018, 11:41 AM | #69 | |
Thank you Al Oppenheiser!
So buy one and tell us how well it works!! |
08-26-2018, 05:33 PM | #70 | |
Thanks for replying. Tough choices. For now, I'll need that $2500 to go towards my 427 build.
Tags |
chiller, cooling, heat exchanger, hex, pulley |
