02-11-2015, 05:58 PM | #183 |
Drives: 2010 rs 2lt Join Date: Aug 2012
02-11-2015, 07:48 PM | #184 |
Drives: 2010 Blue Camaro RS Join Date: Jul 2008
The only reason I'm doing this is because chazcron said it was okay for people to tweak his render, In no way am I trying to take credit for his awesome work.
But... I did want to show how I think the headlights will be exposed through the fascia. I did this real quick with paint just to get an idea. Its a really small change, but a little more accurate. |
02-11-2015, 08:10 PM | #185 |
Optimus Prime
Drives: Camaro ZLS [COTW 09/22/14] Join Date: Dec 2012
That's really nice!!!
02-11-2015, 08:55 PM | #186 |
Drives: ????? Join Date: May 2007
So this one, then?
looks very close to the render that's up above....
02-11-2015, 09:07 PM | #187 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
Yep, There might be a reason for that
02-11-2015, 11:31 PM | #188 |
Drives: RS Join Date: Jan 2013
02-12-2015, 01:31 AM | #189 |
Drives: 1992 Camaro Z28 Showcar Join Date: Sep 2009
We're missing the LED strip that was shown under one of the camouflaged cars..
1992 Camaro Z28. Blue/silver, Custom Blue/Silver Leather seats, Rebuilt Engine, Cammed, Headers, TT ][ Rims ...
NEW WWW.CAMAROSOURCE.CA Camarosource.ca FACEBOOK PAGE - EXCLUSIVE INFO On upcoming Camarosource.ca V5.0 and More!! |
02-12-2015, 04:04 PM | #190 |
Drives: 2014 Camaro 2LS Join Date: Apr 2014
Unfortunately these particular possible 2016 headlight do not have any type of halo. It also appears that the LED strip at the bottom is purely a DRL and most likely completely shuts off when the headlights come on.
02-12-2015, 04:09 PM | #191 |
Drives: Really Slow Join Date: Apr 2010
looks like they have halo's to me
02-12-2015, 04:11 PM | #192 |
Sorry, these don't. I promise.
02-12-2015, 04:28 PM | #193 |
Most cars don't turn off the LED DRLs when the low beams come on. They just reduce power to them so they are not as bright. My 328i does this.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
02-12-2015, 04:31 PM | #194 |
I think that frosted white "wing" sweeping under the projector lamp will likely light up instead of a halo.
Isn't it time to move on from Halos anyway? |
02-12-2015, 04:47 PM | #195 |
Correct, in most cases. That's how the drls in the 14-15 rs cars work. If you were to look inside one of those headlights, you'd see three wire leading to the circuit board controlling the leds. In this case, the ballast visible is an LED ballast which powers the drl strip. It only functions with a single 12v source and one ground. That doesn't really allow for a switching of the brightness. Now perhaps feeding the 12v terminal with say 6 volts would result in a less bright setting. However if that is the case, it is controlled elsewhere in the car, not in the headlights.
02-12-2015, 04:54 PM | #196 | |
