Roto-Fab
Old 02-17-2016, 06:39 AM   #1
WILDRACER
WILDRACER
WILDRACER's Avatar
Drives: 2010 2ss/rs IOM.
NO HEAT
hey guy sorry if this is in the wrong spot ....but I have a 2010 2ss/rs.
that as of yesterday I noticed that I wasn't getting any heat coolent temp was normal 196-198. I checked the radiator and the little bottle on the side and both where full. please help not sure where to turn next.
WILDRACER is offline   Reply With Quote
Old 02-17-2016, 06:53 AM   #2
motorhead
Sound like it's in the control system if the rad level is full.
Old 02-17-2016, 07:49 AM   #3
Josh @ Spartan LSX
Josh @ Spartan LSX's Avatar
Drives: A wrench
Could also be a clogged heater core.
Josh @ Spartan LSX is offline   Reply With Quote
Old 02-17-2016, 08:14 AM   #4
xc_SS/RS
Drives: 2010 Camaro SS/RS
Aren't there check valves in the hoses that run to the heater core? Maybe the inlet one is stuck?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 02-17-2016, 08:30 AM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
Could be an actuator in one of the doors that opens and closes to let in cold vs hot air through the vents
vroomapunk is offline   Reply With Quote
Old 02-17-2016, 11:03 AM   #6
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
How many miles? I would guess clogged heater core.
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
Trob85 is offline   Reply With Quote
Old 02-17-2016, 11:06 AM   #7
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Most likely a bad made in China actuator that has stripped plastic gears .Did you hear a clicking/thumping noise coming from the dash B4 it stopped working ?
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 02-17-2016, 11:59 AM   #8
WILDRACER
WILDRACER
WILDRACER's Avatar
the car has only 52385 on it and it is all stock
Old 02-17-2016, 12:00 PM   #9
WILDRACER
WILDRACER
WILDRACER's Avatar
to be honest with you as with the clicking sound that I wouldn't know I play my music kinda loud in the car
Old 02-17-2016, 03:15 PM   #10
GONIF
GONIF's Avatar
Try setting you controls to heat fan on high , then disconnect you battery overnight then hook up you battery and drive the car and see if that wont reset it . it will have to come up to temp B4 you get heat .
Old 02-17-2016, 08:48 PM   #11
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
[url=http://goo.gl/9m0nNJ Posted by WILDRACER[/url] hey guy sorry if this is in the wrong spot ....but I have a 2010 2ss/rs.
Hi WILDRACER,
I am sorry to hear of this heat concern you've encountered with your Camaro. I see that you are seeking advice from other forum members, and some great suggestions have been made, but don't hesitate to send us a private message if you would like to visit your dealership to have this addressed. We can certainly facilitate an appointment on your behalf and research this further. Please send us a private message containing your full contact information, VIN, and preferred dealership if you would like our assistance.
Sincerely,
Julie C
Chevrolet Customer Care
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
Chevrolet Customer Svc is offline   Reply With Quote
Old 02-18-2016, 07:31 AM   #12
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Don't forget to check for a bad stat, easy to do. It could be stuck in a partially open position allowing constant flow so the water never has time to really heat up as needed.
HOJO is offline   Reply With Quote
Old 02-19-2016, 06:19 AM   #13
WILDRACER
WILDRACER
WILDRACER's Avatar
here is an up date on my heating problem. I took it to the dealership and had them take a look at it and well the fix is a new heater box. the little flapper that opens and closes for the heat temp broke off the actuator and its not cheap.... 8-9 hour job 1500 bucks..
Old 02-19-2016, 08:39 AM   #14
Merc
In The Circle
Merc's Avatar
I'm guessing you have to remove the windshield to fix it? No matter how you slice it that's just bad engineering on GM's part.
