09-04-2022, 07:53 PM | #141 | |
09-04-2022, 09:23 PM | #142 | |
Drives: 2020 SS 1LE Join Date: Aug 2020
Going slow because Northern California is on fire. 111 tomorrow and 112 Tuesday. Luckily we catch a break with a mild 108 Wednesday :/ |
09-07-2023, 02:25 PM | #143 |
BLEW BIU
Drives: 2018 2SS 1LE Hyper Blue Join Date: Oct 2017
Has anyone installed these bushings? If so, how was the install? My stock bushings are getting soft & will need to replace in the near future.
09-07-2023, 03:14 PM | #144 |
Drives: Camaro 1ss Join Date: Nov 2019
Probably the hardest one to change.. Its a PITA
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
09-07-2023, 03:19 PM | #145 |
BLEW BIU
09-07-2023, 09:14 PM | #146 |
Remember most of the OEM suspension bolts are TTY and need to be replaced with new ones, this includes when SPL says "using OEM hardware". Look at the suspension part number mega thread for more details or the service manual.
https://www.camaro6.com/forums/showt...y#post10210721
01-30-2024, 11:36 AM | #147 |
BLEW BIU
Wanted to give a quick update on the SPL Front Caster Rod Bushings (see pic above) and increased caster. Got them installed and new alignment settings. Went to ECR on Saturday and car felt amazing. No issue with bump steer as I was concerned having > 9* caster might cause that. Car felt better than ever.
01-30-2024, 07:50 PM | #148 | |
01-30-2024, 07:58 PM | #149 |
BLEW BIU
04-30-2024, 12:03 PM | #150 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
Has anyone installed the rear upper arms with eccentric lockout? I saw a YouTube video of the eccentric lockout install and he had a hard time with it.
04-30-2024, 01:16 PM | #151 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
04-30-2024, 02:16 PM | #152 |
Great, thanks. Is the re-used OEM hardware on the rod end or the clevis end? Want to buy the right bolts since they are TTY.
04-30-2024, 02:26 PM | #153 | |
You would need to buy new ones for both rod ends. You also need to disconnect the lower part of the rear strut to drop the lower arms I think. I'm not sure if that one is a TTY bolt. |
04-30-2024, 04:08 PM | #154 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I would highly recommend replacing the 1 OEM outer toe link to knuckle bolt on each side as they're TTY. Also I'd recommend using the torque + angle from the shop manual (74 lb ft + 105°) rather than just 74 lb ft recommended in the SPL directions especially if reusing the bolts (which again I don't recommend). Either way, it is very important to put a wrench or socket/ratchet on these bolts regularly to make sure they're not coming loose to prevent a snapped bolt like I experienced last year. One more session on track that day and I probably would have crashed but I got lucky that my bolt snapped at low speed leaving a gas station that night instead. I'd further recommend using loctite both in the hole and on the threads although it is not called for in the shop manual. I used orange because red is a pain to deal with in my experience. I went with about 100 lb ft with loctite (vs. 132 lb ft dry with reused bolts to reach the specified torque + angle) and they haven't loosened after 5 track days. *Paint pen markings don't accurately show tightness on this bolt because of the stuff sandwiched in between so don't make the same mistake I did of relying on those...make sure to physically check bolt tightness. My installer reused my bolts and torqued them "to spec" (I'm guessing 74 lb ft with no additional angle). He advised that it would be a good idea to replace the bolts eventually but he said he used red loctite and that they'd done the same thing before on other cars without issues. My bolt snapped less than 3 months after it was reused when the SPL rear toe arms with eccentric lockouts were installed. There was only evidence of red loctite on one side but apparently it was only used on the bolt threads and not in the threaded hole because the bolt on that side was loose too but it hadn't snapped yet. I also reused this bolt once previously (only the side that I found loose but not snapped) with the stock toe link when I replaced a failed rear hub; I torqued it to the previously mentioned 74 lb ft + 105° that time and had no issues but the stock toe links probably put less force on the bolt because of the rubber bushing. 11609598 is the outer toe link to knuckle bolt part number. You will need one for each side. Last edited by cdrptrks; 04-30-2024 at 04:28 PM. |
