Old 08-17-2017, 06:12 PM   #1
03silvers
Drives: 2017 1SS 1le
Where is everyone mounting zl1 adding lift points ?
Searched everywhere. Rears are obvious. Only one cutout of the plastic rockers. The front of the car has 2 cutouts in the plastic where they can be mounted. I'm thinking the one closest to the front wheel (by aluminum brace in pic). Trying not to overthink this
2017 1SS 1le NGM
03silvers is offline   Reply With Quote
Old 08-17-2017, 06:33 PM   #2
JeromeS13
Drives: 2017 1SS/1LE
Yes, mount them on the forward mounts. Use the middle points to lift the car with your floor jack.
Old 08-17-2017, 06:53 PM   #3
03silvers
I'll be using the addons to lift with a floor
Jack. I'm assuming either of the front cutouts work fine but just wanted to know what others did
Unless you're saying to get the car up to mount the lift points, jack the car from the middle point?
2017 1SS 1le NGM
Old 08-17-2017, 06:57 PM   #4
JeromeS13
If you're just doing a quick lift, yes, you can use the front with a floor jack. If you're going to put the car on jackstands, use the middle cutout (I use a ZL1 mag pad) to get the car in the air, and put the jackstands under the ZL1 "permanent" mounted pads on the front.
Old 08-17-2017, 09:22 PM   #5
Mlbraptor
Drives: 2017 SS 1LE
I can't get my magpad to stay in place.
Mlbraptor is offline   Reply With Quote
Old 08-17-2017, 09:51 PM   #6
03silvers
Right on. Attaching them to the furthest front area possible
2017 1SS 1le NGM
Old 08-17-2017, 11:07 PM   #7
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I put mine NOT closest to the front tire.
-Bobby
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 08-17-2017, 11:36 PM   #8
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
i asked and you can not just buy 2 pads. only sets of 4
Old 08-18-2017, 01:12 AM   #9
03silvers
So sounds like everyone is putting them different places and they all work.
2017 1SS 1le NGM
Old 08-18-2017, 01:22 AM   #10
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
For those with ZL1s, and have used them, do the pads drop low enough? I haven't installed mine yet and just kind of stuck them in place to get a quick unofficial visual. Didn't seem like the dropped lower than the side skirt....so will still be tricky using a floor jack.
ninetres is offline   Reply With Quote
Old 08-18-2017, 09:15 AM   #11
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
Drives: 2017 ZL1 A10 HBM
Send a message via ICQ to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
Mine are fine
2017 Hyper Blue Metallic ZL1 A10/CF Hood Insert/PDR/NAV MODS: Rotofab CAI/V-MAX CNC Ported Throttle Body/Clear Bra/LED Reverse Light/Rock Guards/Lift Pads/Darkened Tail Lights/Ghost-Tinted LED Side Markers/Darkened 3rd Brake Light
FLYNNZL1 is offline   Reply With Quote
Old 08-18-2017, 10:08 AM   #12
JCunningham
Drives: 2017 2SS M6
they drop just far enough
