01-08-2015, 10:14 AM | #1 |
Drives: 2018 Camaro 1LT Hyper Blue Metallic Join Date: Nov 2013
30% less weight, or 30% more power?
If all the Camaro models across the board (z28/ZL1/SS/LT/LS) could come from the factory with either 30% less weight, or 30% more power, which would you prefer?
01-08-2015, 10:15 AM | #2 |
Drives: 2014 2SS RS Coupe Join Date: Aug 2013
MORE POWA!
01-08-2015, 10:18 AM | #3 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
less weight
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
01-08-2015, 10:21 AM | #4 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Depends on what you are doing with the car (drag strip vs road course) and where that weight is coming from (how much is rotating mass).
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
01-08-2015, 10:24 AM | #5 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Weight equals safety, but I'll gladly take more power.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
01-08-2015, 10:25 AM | #6 |
Drives: E92 BMW M3 Join Date: Oct 2012
Less weight.....anybody that has experienced the affects of removing weight vs. adding power will feel the same way.
This is of course taking in to consideration the SS has now, and in 2016 will have no less than, 426hp(LS3).
J-Rod Built and Matt@FSP Tuned |
01-08-2015, 10:25 AM | #7 |
Dazed &
Drives: matte blue 2014 z28(186) 2015 R1 Join Date: Jun 2013
less weight!
01-08-2015, 10:26 AM | #8 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
weight
01-08-2015, 10:34 AM | #9 |
Drives: 2010 Silverado. Stock height now Join Date: Oct 2014
Less weight equals more power.
01-08-2015, 10:37 AM | #10 |
weight for sure
01-08-2015, 10:47 AM | #11 |
Drives: 2011 2SS/RS A6 Join Date: Sep 2014
Less weight (removed from the proper areas) will make the car accelerate better, stop better, and turn better. More power really only helps acceleration.
01-08-2015, 10:56 AM | #12 |
Less weight, for sure. But 30%? That's around 1,200 lbs... where are you going to find that much weight you can get rid of and still maintain safety and stability like we have now? Can't be done. A 10% reduction (400 lbs.) would be miraculous!
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
01-08-2015, 11:10 AM | #13 |
Drives: 2011 Summit White Camaro SS (LS3) Join Date: Sep 2014
Weight is harder to reduce than adding more power. I'd go for less weight and then add power myself on top of that!
01-08-2015, 11:17 AM | #14 |
Drives: Camaro Join Date: Apr 2012
Weight. I think that's the reason my 3rd and 4th gens were more fun to drive, you could toss them around. The camaro manages to feel heavier than it is.
